Brakes > ea rear backing plates machied for irs
https://forums.aussieveedubbers.com/threads/41203/brakes-ea-rear-backing-plates-machied-for-irs
seagull ·
seagull > neil
perth wa
0417997746
item> I have a set of ford ea series ( backing plates )that have had the ( ford holes welded ) and machined out to suit the vw rear irs patten < bolt straight on .
They look like a factory item
cod bead blasted , so they look like new
$120.00
plough ·
Neil, some questions.
What else would I need to do a
rear disc conversion?
I'm in Qld, would they comply with Machinery /Registration authorities here or would I need a separate engineers cerificate?
regards,
Glenn
seagull ·
Glenn , you would be better to may be have a look through the tech section as there has been many posts on this subject .
I have had many of the conversions passed with no problems , but your state I dont know , others have them fitted .
hellbugged ·
i know youre saying for irs, but would they fit swing axle as well. keen if this is the case.thanx
seagull ·
yes they are the same , seagull
seagull ·
This is my last set and includes post in Australia
