do 009 s fit Type 4 motors?
https://forums.aussieveedubbers.com/threads/41222/do-009-s-fit-type-4-motors
waltermitty ·
do 009 s fit Type 4 motors? YThanks in anticipation, Michl
toplessbug ·
certainly do will go straight in BUT you will be a lot better off if you use a stock dizzy if you can. what carb/s are you using??
waltermitty ·
just planning ahead, I intend to do up a Type 4 in the future and was wondering aboutdizzies. It would have dells webers or perhaps aftermarket fuel injection. Mitchell
56astro ·
Mitchell,
The 050 is a good dizzy for type 4 engines
Robo ·
I had a 009 on mine, but went back to the stock dizzy after a while.
Rob...
Robo wrote:I had a 009 on mine, but went back to the stock dizzy after a while.
Rob...
Why?
Robo ·
Had a bit of a flat spot, I spose it is cause the Kombi engine is a bit of a plodder, it's rev's that make a mechanical advance work.
Rob..
toplessbug ·
if you are doing aftermarket inj why not go the whole hog and do timing as well there are plenty of a/m modules to do it and theres a wealth of info on ign maps alljust a crank trigger away
waltermitty ·
Thanks Toples that is the answer of course thanks.Mitchell
bus914 ·
how do you do a crank trigger on a type 4 with the stock fan?
it may be better to get an electronic dizzy that has a second sensor for crank angle. Vintage sell them last i heard, or you can modify a magna efi dizzy.
mnsKmobi ·
waltermitty wrote:just planning ahead, I intend to do up a Type 4 in the future and was wondering aboutdizzies. It would have dells webers or perhaps aftermarket fuel injection. Mitchell
http://www.aircooled.net sell a new dizzie for type 4 engines that is tailored to a variety of aftermarket carbs.
56astro ·
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=IGD0002&cartid=
