petrol leak at carby
https://forums.aussieveedubbers.com/threads/41252/petrol-leak-at-carby
lucylawless ·
i had a electric petrol pump for a while but the noise that it would make was just too loud.even when it had petrol in it.
sp i took it back to see if it was faulty a couple of weeks later that swaped itover for another one very good not a sound.
but it started to push the petrol into my craby so strong that you could hear it gurgle.
i replaces the needle and seat yes the gurgle stopped but it still leaks a little petrol still from the same spot on the carby.anyone can suggest anything other then putting on the old pump.please
akean1 ·
i havnt had any experience with these, but sounds like the pump is pushing pretty hard, maybe putting a fuel pressure regulator between pump and carby would help
76camper ·
definantly need a regulator... not sure about what pressure it should be set to... some1 here will know...
lugnuts ·
2.8psi at 3,400rpm for a Pict-30 dont know if the rest are any different :o and 3.5psi at 3,400rpm for a 34 Pict-3 :Pnn[ Edited on 4-7-2005 by lugnuts ]
76camper ·
there ya go! one question... if its an electric pump, and you have a regulator, wouldnt it just be set at one pressure setting.... or is that the output of the stock pump, thats why ur writing rpm?
lugnuts ·
lugnuts wrote:2.8psi at 3,400rpm for a Pict-30 dont know if the rest are any different :o and 3.5psi at 3,400rpm for a 34 Pict-3 :Pnn[ Edited on 4-7-2005 by lugnuts ]
This is the fuel pump pressure for the stock mechanical pumps.
Vw nutter ·
where is it leaking from?????
just take the carb off and inspect the gaskets/seals,
if there are any bad seals replace them then go from there.i recently bought a carb rebuild kit and there'v got pretty much every gasket/seal u need. but maybe its just one little seal u need!.
toplessbug ·
slightly off the subject ..did you get your front end sorted out yet??? and whats wrong with a mech fuel pump they are made for the application:beer:beer
