hokay.
the other post proved its past time to waterproof the buggy. http://www.aussieveedubbers.com/forum/viewthread.php?tid=41255
the air intake was high enough. i've found the little breather hole on a spare trans and will hook a breather hose onto mine when its next accessible.
- do the rubber dizzy covers work or do i just use freezer bags and tape on an as needed basis?
- i can put the engine breather higher. wonder how much water gets in through other places like the oil filler and oil slinger?
- how well to the leads seal, is there a better way to make them seal?
- do i silicone over the coil terminals?
- if it keeps running i dont need to put a hose on the exhausts?
is it possible to get it so it keeps running a bit longer when submerged, i almost made it through. seems though it was electrics that stopped it. then it was the sitting waiting to get it out that contaminated the engine and trans oils.
nn[ Edited on 8-7-2005 by helterskelter400 ]
helterskelter400 ·
