Thanks for sharing this one, Steve.
That is awesome stuff!!
jvl054 ·
Engineering at its best!!almost as good as my chassis:thumb.....Well done Steve keep and eye on this one.......Steve do you remember a bloke name Billy, 1996 Vw shootout that was doing a front mount V8 dub tube chassis.He had a Rotary bug ther the same day.Have you heard or seen the car finish?JVLRacing
Hi John
Cant remember those cars, I work shifty work and the Shootout is often on when Im working. The V8 chassis is designed by Rorty designs in Melbourne http://www.rorty-design.com/index.html
jvl054 ·
1303Steve wrote:Hi John
Thanks Steve.JVLRacing
subaruboxer ·
jvl054 wrote:Engineering at its best!!almost as good as my chassis:thumb.....Well done Steve keep and eye on this one.......Steve do you remember a bloke name Billy, 1996 Vw shootout that was doing a front mount V8 dub tube chassis.He had a Rotary bug ther the same day.Have you heard or seen the car finish?JVLRacing
how would something go cost wise and licensing wise with a mid mount v8 bug?
Anthony
pete wood ·
Umm, if you modded that chassis design a little you could probably get it regoed in NSW providing the engine wasn't too big.
BTW, can't wait until Jak Jones sees this thread. 😀
I think once the chassis is changed to this extent it would be an individually constructed vehicle. That’s a whole new can of worms that I know nothing about. Jack Jones is probably busy tightening his tent ropes at the moment, just wait until the wind drops a bit.🤘
pete wood ·
As long as you kept the centre tunnel, it would be like a full rear end on a drag car. My engineer said it was important that the pan resemble the original one recognizably if you wanted to register things as rebodied beetles. I'm guessing it'd be the same for this. Then again with all the new changes you might be right.
71superbug ·
yaeah was thinking of purchasing plans and doing such a thing.
would come under same category as old rods i imagine??
Anthony
pete wood ·
HRmatt would know about that. But apparently, there are some peculiar laws relating to the age of the original car that make it difficult for dubs to be registered as rods. That, and I suspect some rodders are a bit non-VW.
HotRodMatt ·
It would be an ICV even if on SR plates.
Most rodders aren't non-vw, they tend to be non-vw people who tell them why they should accept them.
Under the rules if the car can gain enough points to be an ASRF classified car (Mild Custom or Wild Custom) you should be able to get SR rego. If the TAC rep will accept it and in the end it's down to them and do they want to piss off clubs?
ASRF classes:
Hot-rod - Pre '48.
Classic Custom - American Origin, pre '71, separate removable chassis and body fastened by standard automotive fasteners.
Mild Custom - Pre '71 with (I think 200 points)
Wild Custom - Pre '71 with (I think minimum 400 points)
The points system is antiquated and gives more points to frenching of headlights then to relocation/redesign of driveline... Sorta done to keep it to cars for which it was developed - ie American.
The change in engine position, the redesign of the chassis and such would almost certainly make it an ICV. High speed brake and cornering tests. Side intrusion bars, current emmissions rules crumple zones.
If you have the $, time and good engineering then why not?nn[ Edited on 11-7-2005 by HotRodMatt ]
Baldy67 ·
that is just insane...............but i love it:jesus
pete wood ·
HotRodMatt wrote:Most rodders aren't non-vw, they tend to be non-vw people who tell them why they should accept them.
Makes sense, I don't like V8 meatheads who try to tell me why I should love V8s so much.
Have you got a link to the point system thingo?
Who was it set-up by? National or state rego people?
HotRodMatt ·
pete wood wrote:Have you got a link to the point system thingo?
Here's the thing. You can't get the rule book unless you are an ASRF member.
I have a friend that gives me the bits I need from time to time.
As it is ASRF affiliated clubs (or being a lone wolf ASRF member) that control the SR scheme it's a case of you have to get acceptance first before you even consider SR rego.
pete wood ·
without being nasty, that's a bit exclusive isn't it. lets say someone builds awesome cars but has the personality of limp carboard and the social skills of a nailgun, they'd really be behind the eightball.
HotRodMatt ·
Not the person... the car Pete
junkyardoval ·
I have a set of plans for that chassis. My plan is to mount my 2.0 Suby twin turbo in it with the 56 Oval body. Have a friend who is helping me with the Oval who is willing to help build the chassis. He is a retired machinist and likes to try unusal builds. He just finished a 1970 VW fastback with a 2.2 Suby and a bus trans. He also has a Vanagon with a 2.2 Suby in it. We welded the roof back on the Oval last Saturday and will work on the wiring harness next. We hope to have the Suby engine mid mount and still have enough room for a rear seat. Still lots of measureing to do.
pete wood ·
HotRodMatt wrote:Not the person... the car Pete
oh... :blush
jvl054 ·
junkyardoval wrote:I have a set of plans for that chassis. My plan is to mount my 2.0 Suby twin turbo in it with the 56 Oval body. Have a friend who is helping me with the Oval who is willing to help build the chassis. He is a retired machinist and likes to try unusal builds. He just finished a 1970 VW fastback with a 2.2 Suby and a bus trans. He also has a Vanagon with a 2.2 Suby in it. We welded the roof back on the Oval last Saturday and will work on the wiring harness next. We hope to have the Suby engine mid mount and still have enough room for a rear seat. Still lots of measureing to do.
This sounds good!Any details on the chassis?JVLRacing:thumb
junkyardoval ·
I haven't started work on it yet. I would like to get the current version running before starting on the chassis.
Ernie
jvl054 ·
junkyardoval wrote:I haven't started work on it yet. I would like to get the current version running before starting on the chassis.
Ernie
Hi Ernie, are you going to design a full all half chassis and are you using CAD (computer)for designing?..... I found it was alot easier and learnt more that way with my Engineer.Are you in Australia or overseas?JVLRacing
junkyardoval ·
I am in the United States. I have the blueprints from Rorty. I think it is a nice chassis design. I am sure I would have to do some redesign on the rear for the Suby engine. I don't have a cad program, but the guy who is going to help me is pretty good at design work. He has built some pretty wild cars in the past. He has a 1952 Jeep pickup with a Chevy V6 and auto trans. It has a Mustang front suspension and airbags on the rear. The cab has been extended 14". He has built two Vanagons with Suby 2.2 engines. A nice friend to have. He laughs at some of my ideas.
71superbug ·
tripped out...why are u going the mid mounted subie twin instead of something that can pack a couple extra ponies..like a 1uzfe lexus motor..
Anthony
junkyardoval ·
I have the Suby already in the Oval. Just want a better chassis. This engine is rated at 300 HP. I think that will be enough for me.
71superbug ·
i am thinking about looking at something like this for a second project..except with the lexus 1uzfe 4l lexus v8..maybe even forced induction..but at the moment the bug will stay rear mounted engine and still be quick enough for me 🙂
Anthony
tassupervee ·
Hmmm reminds me of a certain T3 thing in baby shit mustard brown colour that used to race at Oran Park mebbe 25 years ago.
Never looked inside but it was powered with (from memory) a 5 Lt Holden V8 boat anchor thing. I cannot remember whether it was mid-mounted tho.
I do remember it went like stink......in a straight line!
Corners were a little different LOL.
L8tr
E
