fuel line in manx swb
https://forums.aussieveedubbers.com/threads/41862/fuel-line-in-manx-swb
devilbug ·
has anybody replaced a fuel line through the tunnel,if so i would appreciate any info on how to do it because it looks like a pain in the butt,or any alternate ideas, cheers kevin.
I threaded a new tube through mine; in through teh fuel ine hole up front and out through the gearshift rod hole at the other end.
devilbug ·
thanks for the reply,so was it easy or a pain,cheers kevin.
~air fooled~ ·
yes have the same problem devilbug as it seems whomever shortened my austrum just took out the pipe and run hose the entire length of the tunnel...
phantom ·
Fuel line in my SWB has been run beside the tunnel in the car (drivers side), the guy obviously decided it was too hard to go through the tunnel.
bigbaja ·
use 8mm od tube if you are replacing
and it is best to start from the front and try to feed it under every thing in the tunnel
then when it is at the rear you can put a little bend in it and feed it through the hole in the fork by holding it at the gear shift hole
then cut it to lenth and bend the front end pull through a little further and push it through the front hole
not real hard at all when you have done one
best to get down with a bright light and look up the tunnel so you can visualize what you doing first
good luck
terry
~air fooled~ ·
hey tezza... thanks for the directions! how do you bend the pipe at the end when it is fed up to the fork?
