Anyone parting out a Karmann Ghia??
Chasing a steering column, shaft & tube;
as early model as possible, 1960?
these are a little longer than equivalent beetle item.
Andy
Sunshine Coast
07 5449 9066 (B)
Grey 57 ·
Is an oval era Beetle one the same? Got one here complete.
REDKG ·
the steering column in my 1960 is original and is the same length as a beetle . swapped it over whilst the original went for blasting and paint.
lowrider ·
Dean,
Would you mind measuring it for me, the actual steering shaft?
I have the required length written down here somewhere.......
Over at the Samba they reckon the KG is longer(?)
It'd be great if they were interchangeable.
thanks.
Andy
The measurement I got from the Samba was 95.5cm, not counting the
part that attaches to the rubber coupling.nn[ Edited on 19-7-2005 by lowrider ]
Grey 57 ·
Hey Andy the steering coloumn is 725mm end to end
REDKG ·
i measured my kg column at 945 mm
lowrider ·
plot thickens eh?
I should dismantle the 70's one thats in the car & measure ...
maybe there's only a centimetre in it.
It's a lowlight, so I'm trying to keep that original look.
thanks Red & Grey
Grey 57 ·
This colomn is off a 57 big window beetle.
Over 200mm thats a big diff. I will chack the part no for both in a early VW parts book I have.
Grey 57 ·
Bugger , the book only covers Beetles up to 59/60.
But the Beetle part no is 111 415 555 B. If thats any good to you
karmen ·
Am seeing a vw guy in Bundy who is retiring and had some KGs and lots og stuff
can check 4 u
if you ring me by 10 am
o421286423 cheers bernie
