another hole ???????????? golf
https://forums.aussieveedubbers.com/threads/42024/another-hole-golf
karmen ·
I have a hole in my bellhousing so schmoke and schlipp clutch happens. emits gear oil
if i kleen reely good what can i use to block it/ glue it ...will have some pressure from diff.
is about size of cotton bud end.
happened when a piece of chisel from trying to stop flywheel 4 timing -broke off and slammed around in clutch dept.
I thought 3-4 staggered attempts of araldite..any good ideas
thanx
MikeM ·
karmen wrote:happened when a piece of chisel from trying to stop flywheel 4 timing -broke off and slammed around in clutch dept.
:duh you're lucky thats all that happened...... :o
karmen ·
yeah mike am goin nuts here cause pulled out g/box and again had to put off gettin my Baja i bought recently.
the chisel was half inch by 3 mm x 3mm but when i was doin about 160 kmh it must have sucked up the piece by the speed of the flywheel.shame it is a VW Seat Cordoba and has been truoble free for 235 G's
Kombi_Rescue ·
you can try and tap the hole ..say 4-6mm and fit a plug...screw it in with a two part liquid metal...bingo oil leak cured ..ps make sure the plug sits flush with the inner housing..if the hole is smaller go down a size...tip when drilling or tapping use lots of grease as it collects the fillings easy....dont panic if some falls inside the g/box ..the material is qiute soft and wont have to much affect on the working internals good luck cheers steve
karmen ·
great idea ...thanx...got me to think that
i might rawlplug it as rubber will corode but wralplug will expand with a countersunk screw init with araldite around it
will see vw man t'mora
Peter Leonard ·
drill and tap the hole for a 1/4 inch threaded allen headed grubscrew, and put some loctite 577 on it. bingo.
karmen ·
u beauty taa alls
