leaking pushrod tube
https://forums.aussieveedubbers.com/threads/42033/leaking-pushrod-tube
oval TOFU ·
..will I need to take my head off? ie: engine out?
Old Dubber ·
If it's a type 1 ..... yes
But, this may help. I was down at Mick Motors last week and Mick was showing me a new collapsiible tube. It can be inserted by only removing the push rod. This has been made from two normal type tubes, with one socketing into the other, has two 'O' rings, held in place with a circlip. Still has the standard concertina ends. Best idea I've seen for years.
oval TOFU ·
sounds intereting... I'll investigate...I'm not too keen on getting my engine out again...
yes - no - ish
You "CAN" use screw in replace ment tubes.
DO NOT USE THE SPRING LOADED TUBES. THEY ARE CRAP.
They are about $25 each but yes it saves pulling the motor and taking the head off.
Just make sure everything is clean clean clean
oval TOFU ·
i'd rather spend the $ than take my motor out - it's a real tight fit in my oval for some reason... where do ya think I can get em Bizarre?
most VW shops.
I puleed a motor once and some goose had used 8 of the screw in types :jesus
VVDS sells them but depends on what they can get their hands on - some times screw - in some times spring in
maybe check Mick as well. Volkspower??
