ELECTRONIC IGNITION SPECIAL
https://forums.aussieveedubbers.com/threads/42061/electronic-ignition-special
classic veedub ·
FOR ALL VEE DUB LOVERS !!!!
ELECTRONIC IGNITION FOR ONLY $68.99 A KIT
BEETLE WEST COAST METRIC RUBBER KIT AMERICAN OR CALLOOK FOR ONLY $134.99 (4PCS KIT )
ONLY FROM classicveedub.com.au
Stanley ·
Tell me more about the EI
helterskelter400 ·
good value man (this is an unpaid advertisement).
i got one of his points replacements on his last special - $67 is still a grreat deal.. wow. if its the same as the last, its an accufire;
it fitted too easy and works great. accufire, with my su12 coil & 009 dizzy.
5000 hard km & working great, puts up with sand, condensation and total sumbersion...this sort of abuse (here's the photo agian.. any reason) haha
forget the points gap check, its a thing of the past...
being warned by other points replacement users, i do not leave the ignition on for an extended time. having said that, i do hand crank start the buggy from time to time which means the ignition is on for a while.. (for research pourposes only), and i havne t burnt it out yet.
price points replacement units yourslef and i think you will find this is a good deal.
although he can be hard to catch, it is worth perservering.
does this work with a stock dizzy??
helterskelter400 ·
the one i got had a spacer to use for the 009 with the officila destructions saying no spacer needed for stock dizzy. i would scan if i had a scanner..
VolksFolks ·
Hey Classic, welcome, pleased to see you have finally made it to the forum!
Andy
helterskelter400 ·
took a photo of instructions. how simple is this.
bus914 ·
do you know if it fits a stock (vacuum advance) late bus distributor?
