WTD: Fan Shroud thermo flaps - 40HP
https://forums.aussieveedubbers.com/threads/42185/wtd-fan-shroud-thermo-flaps-40hp
oval TOFU ·
before I go to the volks shops, I'll try here..
I need a oil pressure sender for a T1 - goddit! Thanks Grey57!
A 60's two speed wiper switch - goddit! Thanks Karmen!
Thermo, flaps and arms that go inside the fan shroud for a 1200 40HP. Preferably in Melb area, but would consider anywhere.
Cheersnn[ Edited on 8-8-2005 by oval TOFU ]
Karmann Cruiser ·
Got an oil pressure sender for you.
New VW/VDO part with connection for original oil pressure warning light and one for an oil pressure gauge. Same thread as the original ones.
Price $50.00
Matt
oval TOFU ·
Thanks Matt, I only need a sender for the light. I'm tight on money at the moment, so I don't wanna spend more than I have to, esp if I'm not going to use the pressure sending function of it..
Karmann Cruiser ·
No worries,
I thought I had a standard switch somewhere floating around too but can't find anywhere. Sorry I coudn't help you any further.
Matt
36 HORSE ·
I've got a sending unit you can have if you want to drive to Werribee.
oval TOFU ·
Does it work for sure? Any sunny days coming up? 🙂
36 HORSE ·
Yeah it works.
karmen ·
only 60's 2 speed wip switch i know would be 12 volt in vw and 68 onwards
can get other bits but from qld so some postege if you want email me will check stasch Monday
oval TOFU ·
36 HORSE wrote:Yeah it works.
great, U2U me with a price? or did you just want me to come pick it up?
12V is good, as long as it fits in my 54 dash.. if you can check your stash, that'll be fantastic! cheers
karmen ·
am checking Monday ovtof
karmen ·
ok got you a switch from me vw mech,is out of a 69 and is also a washer button connection olus hose but u can fit orig buttion has the same aluminium holding screw as all bugs.
do u need a button (ivory)
unit is $6 plus post and a tip for haggling and packing if ya wanna...e-mail me or text me ur address and if u want a pic first
0421286423 is def 2 speed.
oval TOFU ·
bumps
karmen ·
mailing Thurs and let you know post cost with bank ac #
oval TOFU ·
cheers K
Grey 57 ·
Got a sender unit here too Chris if you want it. You can pull it off the 36HP motor I have in the shed. Come and get that fuel tap too.
oval TOFU ·
Cool Dean, maybe this weekend? When are you free?
Grey 57 ·
Saturday arvo only this weekend mate. Give me a call 0412 500 588
oval TOFU ·
cool, I got some pressie shopping to do first, but I'll give ya a call.. want me to bring da Genie and heat Xchangers over too?
oval TOFU ·
new needs: bump
