minimum ground clearance on beetles
https://forums.aussieveedubbers.com/threads/42209/minimum-ground-clearance-on-beetles
blutopless2 ·
does anyone happen to know what the ground clearance of a standard beetle is and where it is measured from. gotta raise mine and wanna know how high to go and where i measure it from.
Thanks.
P.S
Don't panic people it will be lowered again later.. :thumb
Midlife crisis ·
In QLD the lowest part of the car must be at least 100mm from the ground whether that be body work or exhust etc.
Marc
barls ·
what he said its australia wide as its in the adrs. from lowest point to the ground
squizy ·
Just to add to this....10cm off the ground is the minimum, but also the middle most point of the headlights must be greater than 59cm.
VWFOOL ·
i heard the exhaust doesnt count, is that tru, in NSW?
barls ·
nope to the lowest point be it the exhaust or body
The only bit that doesn't count is brakes.
59cm to the headlight?
There are a lot of new cars that can't pass this
foxy_fuchsia ·
I have heard it must be the lowest point of the car where it's measured from, and 100mm off the ground. Some people say it's the size of a coke can.
PrettyBlueBug ·
Ooops... I don't think a coke can can fit under my car! LOL 😉
blutopless2 ·
thanks everyone.
At least i now have something to aim for with the height.
