I have a 75 twin cab so they may be the same. To get to your fuel tank,remove both sectionsof the back seat +the base.
have a look under where the tray is , there should be 2 inspection plates , remove these and your tank if it the same should be there . also while you are there clean it out as dust & dirt collects there which may attract moisture then RUST
:bounce:bounce:bounce:
72TWINCAB ·
Thanks Sand Kombi. I will give it a go. It would be great to have a fuel gauge that works properly.
I see your from Brisbane. Are you going to Toowoomba for the show? If so, should see you there. Bill
sand kombi ·
no sorry, 🙁 , work beckons
72TWINCAB ·
That's to bad:cry Looks like I will have to fly the twin cab flag on Sunday.😎
