wat size nut holds on the steering wheel in early beetle?
https://forums.aussieveedubbers.com/threads/42350/wat-size-nut-holds-on-the-steering-wheel-in-early-beetle
VWFOOL ·
im gonig to hav to borrow a socket set to tighten up the nut and need to know wat size ill need.
for the nut holding the wheel onto the steering column under the horn button.
thanks
sam
jnr356 ·
27 mm sam
helterskelter400 ·
izzat 27mm ... the same as the bolts into the end of the frame horns??. someone was thinking.. great... multi use... :]
jnr356 ·
oops...sorry 30 mm
VWFOOL ·
thanks guys very helpful
helterskelter400 ·
doh... not multi use....
lucky i alresady have a 30mm for the steering head of the m/c so i got that one covered if/when...
VWFOOL ·
ah ok so its 30mm, not 27?
helterskelter400 ·
hokies.
even tho its raining and freezing outside. i wen out and measured mine.
my steering wheel nut is 27mm.
and for what its worth i have a 27mm 1/2 inch drive socket and a 30mm 1/2 inch socket so the bolts at end of frame horns must be 30mm!!!nn[ Edited on 2-8-2005 by helterskelter400 ]
helterskelter400 ·
terrible spelling and gramar in last post.
suffice to say mine is 27mm and my buggy was mostly a 67 beetle.
VWFOOL wrote:wat size nut holds on the steering wheel in early beetle?
I hold on to the steering wheel in our beetle and I am a bit of a nut, and I am 6 foot tall 🙂
What size nut... How tall are you?! lol
VWFOOL ·
its a 27mm for anyone interested. thanks
