I have a 1970 Beetle with a 1300 motor and manual gearbox. It's been my daily driver for the past 18months with no real hasssles. However over the past few days when accelerating between 1st to 2nd the clutch slips slightly, engine revs go up but goes back to normal after I ease off. This is only intermitant.
Tonight, I pushed down on the clutch prior to starting the car and the clutch pedal went down to the floor without much resistance.
When depressing the clutch pedal it now engages a few CM's from the bottom instead of the a few cm's from the top. I can still change gears and it seems to drive as normal.
Any one had a similar problem? What do you suggest caused it and what is a possible fix?
kickatinalong ·
