leaking wiper conduits
https://forums.aussieveedubbers.com/threads/42419/leaking-wiper-conduits
oval TOFU ·
How does one seal out the water from dripping into the bonnet area from the openings of the wiper rubbers? I know it could just be the hardened rubber grommets themselves, but could it be the part where the wiper shaft pokes through the body work too?
Grey 57 ·
Yep, thats the reason. Silicon the rubber gaskets up. It could be coming down the wiper shaft too. Lubricate them with waterproof grease.
oval TOFU ·
Sounds easy! ...wiper shaft, that's it. I thik i wrote conduit coz it makes me sound learned.. Isn't all grease waterproof?😁
Thanks for the advices Dean
Old Dubber ·
I use some old inlet/exhaust valve stem oil seals - probably from early BMC or GMH. Fit tight around the wiper shaft and because of their "cup" shape, they cover most of the locking nut, shedding the water away from the wiper shaft.
oval TOFU ·
Old Dubber wrote:I use some old inlet/exhaust valve stem oil seals - probably from early BMC or GMH. Fit tight around the wiper shaft and because of their "cup" shape, they cover most of the locking nut, shedding the water away from the wiper shaft.
!:thumb Where would I get them?
Old Dubber ·
Any spare parts place - Repco
