Wanted - Late bay steering column - FOUND
https://forums.aussieveedubbers.com/threads/42448/wanted-late-bay-steering-column-found
Dozza ·
Anyone got a late bay steering column I can have for not to many $$$$$
Got a really nice deluxe padded steering wheel to go on my latest early bay project..... need a late bay column to get it to fit!
Dozzann[ Edited on 10-8-2005 by Dozza ]
Dozza ·
bump
vwtyp2 ·
nice, where did you get it from? 😉
Brad ·
if you want a bolt in solution you will also need the dash, indicators stalk, plugs, etc etc
Dozza ·
Type2 = bought it off Stealth
Buggy brad - I am sure that is not the case. you can just swop the column.....
Dozza
vwtyp2 ·
Dozza, all you need is the shaft, not the whole column.
A late shaft WILL fit into the early column.
I did the same in my '73 when I fitted mine.
That's right, it was kombikid that I sold my spare one to.
Brad ·
Just so there is no confussion .. if you only want the shaft you can swap it over but if you want the column you will need the entire lot.
I thought you maybe trying to get the later controls as well which is why you wanted the entire column.
If you want just the shaft I can probably help you out with one.
Dozza ·
Thanks for the advice guys, Brad.... picked up a shaft off Wayne up in Buderim today....
Will fit it tomorrow
Dozza
Brad ·
cool, you will ove the big wheel, I could never go back :>
