Where is the best place for new EJ22 parts?
https://forums.aussieveedubbers.com/threads/42497/where-is-the-best-place-for-new-ej22-parts
Transparu ·
I'm after a water pump for the EJ22 in my Transporter and am wondering where is the best place for parts (price-wise)?
Doesn't have to be Brisbane as long as postage is possible.
Thanks folks
Dave
Brad ·
pumps are worth around the $100 mark if that helps.
Zupps had them on trade special a while back for $79.95
Transparu ·
Thanks Brad . . only now just having to buy parts.
Dave
Jenny ·
How do you check if your water pump is OK?
How long has your water pump lasted since you did the engine conversion?
I notice a lot of the people recommend replacing the water pump and thermostat on any engine that has sat for more than 6 months.
My wife gets any Subaru parts we need through her work. She works at a panel shop. They always want the chassis number, so I have written down a good chassis number off a Liberty with the same year so I can always get the right mechanical engine parts.
Our thermostat was not opening after sitting around for so long, so it is worthwhile getting another one.
pete wood ·
what about EJ25s?
I'm pulling my motor out this weekend to sort the clutch issue and it's tempting to do the timing belt/water pump at the same time.
How hard it it to replace the timing belt?
Where would I get a DOHC EJ25 belt in Sydney?
What sort of cash would it be?
Transparu ·
Mine has lasted 3 years since the conversion (makes the engine - and water pump- 12 years old).
It has started leaking coolant and this is coming from inside the timing belt cover. This is apparently the sign to replace it as the seals against the shaft leak and are an integral part of the assembly.
Dave
Jenny wrote:How do you check if your water pump is OK?
Brad ·
if it is leaking coolant from the cover then it is in need or a new one.
Mine has 20 000 km on it without issue so far. I am going to do a belt in another 10 and will probably do it then.
Just a little word of warning... The EJ's water pump drive 'circuit' is shared with the cams... it's all one belt so a collapsed water pump will mean smashed pistons...
Jenny ·
I thought the Ej20 and EJ22 were of the non-interferance type, so if the belt broke you couldn't put a valve through the piston.
Maybe it is the newer EJ25 that is the interference type?
Jenny wrote:I thought the Ej20 and EJ22 were of the non-interferance type, so if the belt broke you couldn't put a valve through the piston.
My engine dude said it was an interference.. better safe than sorry! Regardless, engine will not run real well with no cam belt!
dubbill ·
sub-a-roo-rus sunny coast (also have us spec 2.5 wrx now in stock)
time to get a new engine dude,dude. They are the non interference type n no harm shall be bestowed upon thy pistons should said belt fail in a mannor which would be premature----- ie.NAH SHELL B RIGHT MATEEE oh n the engine will not run real well with no cam belt or even petrol for that matter or oilor plugs or heads ps love eatin wrxs in my rotor yummmnn[ Edited on 9-8-2005 by dubbill ]nn[ Edited on 9-8-2005 by dubbill ]nn[ Edited on 9-8-2005 by dubbill ]nn[ Edited on 9-8-2005 by dubbill ]nn[ Edited on 9-8-2005 by dubbill ]
Jenny ·
According these documents the 2.5L DOHC can get valve/valve interference and the cam sprockets need to be locked when replacing the timing belt http://www.ravensblade-impreza.com/techdocs/pdf/engine/dohctbelt.pdf
http://www.ravensblade-impreza.com/techdocs/pdf/engine/timingbelt.pdf nn[ Edited on 9-8-2005 by Jenny ]
dubbill ·
thats right altough the 2.0 &2.2 were talking bout doesnt👍
Is it common for a water pump to fall to pieces and the pulley drop off so the cam belt becomes loose? I suppose if you change it just when the seal starts leaking it would be ok?
pete wood ·
Well, I want to talk about the 2.5 litre DOHC please. Now that I am feeling doubly hesitant about replacing the timing belt, does anyone have any idea where I'd get one?
Are they the same as the EJ20 DOHC? or are they a different length?
dubbill ·
neva seen that helbus pete asubie dealer is only a phone call away
The only difficulty I found with Subaru dealers is they want a chassis number before they will help with part no's or prices. That's why I have an EJ22 Liberty chassis number I use to get part number and price info, then I fax the part numbers to my wife who orders them through her work.
Well it is her bus, so she can do half the work. :thumb
dubbill ·
really?? an engine no should suffice
pete wood ·
you're a bit bored today aren't you Dubbill
pete wood ·
Just incase anyone is interested,
2.5 DOHC engines use the same timing belt as 2l DOHC engines,
and
All EJs use the same water pump.
Found that out today at the local parts shop.
