sealed beam lights into later model beetle
https://forums.aussieveedubbers.com/threads/42556/sealed-beam-lights-into-later-model-beetle
DIY-DUB ·
plz explain, how the hell do you mount the buggers? no screws, clips or anything, and its a 7inch light goin into a 7.5 inch hole so must need something, im betting im missing something simple but will ask anyway
yeah, good question... I've often wondered this myself... USA cars always seem to have sealed beams as standard... how did they do it, anyone?
BiX ·
There should be 2 tabs bent back at the 10 and 2 posistion inside your headlight bucket. these nned to be bent down. Try heating them otherwise they may snap.
and use the normal bracket at teh base for the bottom mount and also the chrome ring.
DIY-DUB ·
so the tabs support the light, how do ya hold them in place? other than hopes and prayers on the tabs? and how the hell do ya adjust them after that?
BiX ·
you screw through the tabs, this holds them there. teh light is then adjusted using the 2 adjusting screws on each side.
DIY-DUB ·
i must be missing something, theres no way that you can screw these to anything, theres 3 raised bits on the outer edge at the bits that match up with the tabs, but they point backwards, and theres still no hole in them, is there a bracket or something for them that goes between?
DIY-DUB ·
anyone else got any ideas??
barls ·
your talking about the h4 upgrades arent you. cause they just screw to the mounting tabs that are in the guards and you then adjust by the 2 screws fitted
DIY-DUB ·
how do you screw them in when theres nothing on them to screw into? yes tis the h4's. me thinks having a cam 2 take a pic would help me alot right now
barls ·
id love to take a pic but i dont have any in the car im driving.in my other one i do but its not a good pic if you look closely at the right hand light socket you will see where the little clips are about
and i
pete wood ·
Umm, why do you want sealed beams. There are alot more powerful bulbs available in H4 globes. My buggy has 90/130w bulbs. Absolutely awesome at night!
btw, the 4 super oscars help too 😀
DIY-DUB ·
yeah i know about them but the lights themselves dont have anything that could have a screw thru it, and theres still about 10mm gap between the tab and the rim of the light, and yews i have them bent out all the way
barls ·
i thought the h4 upgrades were a semi sealed beam. any way the ones i have in chaos have a stamped ring attached to the lens which is what attaches to the tabs
BiX ·
Same here. they are semu sealed beams. as i understand it, a sealed beam unit, the whole glode and reflector are one unit and are replaced. Semi sealed H4 lights are a std replacement and were used in early golfs etc. like barls said. the semi sealed beam unit, is in a pressed steel ring which has the mounting and adjustment screws. this is then screwed into the tabs on the bucket. and a plain chrome dress ring goes over the top.
DIY-DUB ·
well i think i have dud lights or something then, the ones i have are almost all plastic, other than the bit the bulb actually sits in, and by the description, these are semi-sealed, just without the steel rim with the screw holes and adjusting holes in it
dubbill ·
where did you get those lights??? not imo vw mayby there from a hyundi vw seald lights r not plastic better option to go with h4's unlessyour on a carrot diet n can see in the dark might as well put some candles in those holes as sealed beams😎
DIY-DUB ·
THEY ARE H4's from the vw nationals, said they would fit, they dont
dubbill ·
next step take them to your local vw shop n compare vw of that age rarely made plastic units of anything
DIY-DUB ·
they not made by vw, they r aftermarket things, like all the lights in us, euro, and GL look bugs, well similar anyway
dubbill ·
stay away from the sealed beams anyway if somethin happend to one ( rock) where would you go to get a match???
DIY-DUB ·
go get a new set i spose, not fussed, didnt cost me much, i like the look of em, the original light dont work with my plans for my bug
dubbill ·
from where you dont know what there off there has been soooo much reasearch/technology gone into lighting ova the last couple of yrs its not funny talk to auto bahn they even have a wide variety of lighting solutions best of luck
DIY-DUB ·
look what i found on ebay, the same type lights ive got, thought id post so ppl knew what i was on about
barls ·
yeah mate if thats them your missing the mounting ring which holds them
barls ·
just talked to the old man and they might be t3 kombi
barls ·
found the solution to your problem mate its a narva part and the number is 72190. they are about 30-40 bucks and its designed to hold the lens that you have. its amazing what you find when looking for parts in a catalogue. heres a pic and link to the right section
http://www.narva.com.au/ForwardLighting_24.html
nn[ Edited on 25-8-05 by barls ]
lauzboy ·
im a little confused and would appreciate some clarification.
so if i were to upgrade to semi-sealed units for my '71 bug, id need to remove everything, buy the mounting rings, then the semi-sealed units, the globes and new dress ring? or is there anything that can be used again?
all i want to do is to be able to buy H4 globes that fit properly. the base ring on my reflectors are for the less common H4 type with a full ring base (P45) , as opposed to the 3 tab type (P43t). does anyone know if you can buy new reflectors only with the P43t fitting? this way id only need to replace the reflector and globes, as opposed to everything
http://www.narva.com.au/Globes_17.html
barls ·
no you can just buy the whole unit as ive done but make sure you get the mounting as well thats what 1st bug didnt do so that was why he was having problems. micks has the h4 upgrades for the common h4 bases you just have to be specific when you ask for them. any problems and i can get you a set thru my old man. the unit replaces the whole headlight assy. and is held in with 3 screws takes about 30 mins to fit so long as you have the tabs
Midlife crisis ·
As Barls said, you can use the old chrome ring.
barls ·
also the main reason of doing it this way is that they dont offer a really good range of bulbs in the stock base. hence going to the h4 base.
I've always had sealed beams in My beetles, even back in the 70s...
Now I have H4s in My beetle...
You will need the round headlamp brackets from a 70>
model falcon or maybe holden?
these have the mounting holes in them...
there are different ways of mounting them...
I would stay clear of 90/130w bulbs as these tend to overheat the headlamp electrical plug etc...
Hella/Narva plus 50s are 50% brighter on Low beam and 40% brighter on HIGH Beam and only use 55watts..
You can buy most H4 headlamps at most auto one etc...
barls ·
just spoke to 1st car mate and hes got a bracket now so hes good. but i agree on the nava +50s.
lauzboy ·
thanks Barls!!! yeah im interested in globe upgrades
so what sorta price we talking about for new headlight assemblies?
is it possible to get just new reflectors to replace the ones in the original units?
barls ·
im not sure mate but they come as ether a complete assy or as 1st bought them ie just the lens
barls ·
mikes has them on special this month for 90 bucks for the late model ones
