Ok - i know jack about beams
My friend has a Suth Effricun beetle. A 1968 drum all round job. Being restored now.
Ummm.... what is it?? ball joint or King and Link??? (see pics)
Now she wants discs on the front and to lower it
What should she do??
Dropped spindles??
Beam??
Going to run slightly wider stock wheels.
Is a narrowered beam necessary??
What width with what ET can you run on a stock beam??
When the beam is changed and we put a disc brake set up on do you need to keep it K&L if it is now or can she change to ball joint?? or do you need to change all the steering tie rods etc etc???
Extended shock towers necessary??
Yes - i could ring CBB and wate their time asking stoopid questions.
Want to try and get an understanding before i ring around.
The Classic VW beam excludes torsion leaves. How hard are they to cut??
