Seagull looking for a L10S microtech ecu as if I can not get the subaru ecu sorted I will have to this way .who has the best prices for these down under .
cheers seagull
dubbill ·
go to www.microtec.com.au/auto although we have found the wolf 3d a better match for the subie gmr on the sunny coast qld can sort you one
gull ·
what was the better points of the wolf ?
dubbill ·
infinitly more fuel mapping easier interface with existing hardware
speedster356 ·
I just fitted an LT10s to the Spyder (EJ20T) and it was an easy fit. The base map was a perfect startup.
I found the dealers did it at the same price as listed by Microtech on their website.
I'm sure that you can get the stock ECU up and running.
If you still need the Subi to VDO thing done then give Custom Bugs and Buses in Sydney a call (Mike) and he has a contact for an interface module for just this.
gull ·
Can I have your contact number peter , cheers neil
dubbill ·
weve just installed a corsa spec ej20t sti into a porsche 914 mid mount and the wolf is a dream dont get me wrong we use microtec on all the rotors we have they are a great unit
gull ·
dubbill , would you have a pin wiring diagram on a 3 plug subaru ecu 94 quad cam none turbo motor ?? I having problems locating one for my motor it has T4 on the metal cover
