chassis tuning
https://forums.aussieveedubbers.com/threads/42618/chassis-tuning
dubbill ·
how do you guys tune you chassis do you mainly go tubular??whats the story
shiftyvw ·
tuning chassis generally refers to adjusting things like shock absorbers, spring rates, heights etc. You can tune any chassis to a certain degree but most tube chassis cars have a lot of adjustabilty built into them like multiple pick up points for rear ladder bars etc etc. Tube chassis is generally stiffer as well. Hope this helps.
dubbill ·
i guess weight transfer is not hard to get sorted in a vw ha but some of the torque you guys are pumpin out wow
shiftyvw ·
weight transfer is actually a problem in the real quick stuff. generally need to move weight forward when you start getting into 8's and lower.
jvl054 ·
shiftyvw wrote:tuning chassis generally refers to adjusting things like shock absorbers, spring rates, heights etc. You can tune any chassis to a certain degree but most tube chassis cars have a lot of adjustabilty built into them like multiple pick up points for rear ladder bars etc etc. Tube chassis is generally stiffer as well. Hope this helps.
This is correct.My tube chassis is tuned on a laser aligning machine.They are very accurate using computer tech.Its eye opening the way they work.JVLRacing
So's mine. It's called a WHEEL ALIGNMENT MACHINE
:P
