clutch??
https://forums.aussieveedubbers.com/threads/4263/clutch
BUG11Y ·
What price should i expect to pay to fix the clutch???I only recently bought the buggy and have reciepts for a "kennedy "pressure plate and new clutch what parts can be kept??
Che Castro ·
whats wrong with the clutch?
The standard pressure plate, disk and throw out bearing is around $200 new.
Make sure you get a german pressure plate and Throw out bearing.
throw out bearings are cheap, if your one rumbles or isnt smooth when it turns its stuffed. Replace it anyway if u don't know how long its been there. Its cheap
BUG11Y ·
how many hours worth of labour is in it???
You can do it in a morning.
Better if you have a helper
Che Castro ·
if you can drop the engine you can change the clutch.
what is actually wrong with the clutch?
BUG11Y ·
Buggy won't go int reverse when idling. Is revving out in fourth gear, Clutch just does'nt feel right hoping its just the clutch cable....:bounce
Che Castro ·
so it refuses to go into reverse when u idle? does it go into reverse when its not idling? This doesnt sound like a clutch problem at all.
what do u mean by "revving out"? do you mean its slipping or what?
