where to get - some stainless sheet steel cut?
https://forums.aussieveedubbers.com/threads/42698/where-to-get-some-stainless-sheet-steel-cut
crewcabconnection ·
I need a sheet of stainless steel - supply and cut - to cover the over engine bay top on my splitter, sydney area - any ideas? ideally stuck to about 6mm of ply.
Ummm.. i will say a sheetmetal worker.
I work in air cond and the dust manufacturers would/may be able to do what you want.
u2u me where you are and i can give you some names.
They wont stick it to ply.
Cheapest would be yo get some .5mm sheet and cut it out your self??
Should be able to buy a 8' x 4' sheet pretty cheap.
or maybe a aluminium??
You can get some thicker sheets of that???
sax ·
Check out the laser cutting mobs, I know of one in chatswood and hornsby I think too.
They can cut any thickness of anything and in any way you want. Amazing to watch.
crewcabconnection ·
sax wrote:Check out the laser cutting mobs, I know of one in chatswood and hornsby I think too.
got names and numbers?
sax ·
Ill look em up hang on.nn[ Edited on 11-8-2005 by sax ]
sax ·
Castlecrest Engineering
Unit 2, No. 8 Blackstone St
Wetherill Park
NSW, 2164
Australia
Ph: (02) 9609 3481
Fax: (02) 9609 3498
http://sydney.citysearch.com.au/E/V/SYDNE/0014/92/14/2.htmlnn[ Edited on 11-8-2005 by sax ]
crewcabconnection ·
bless you my son.
sax ·
I went to a huge swapmeet at Fairfield showgorund last week and ran into
the guy who does louvres in decklids and such. He also can stamp the metal
doing text or designs. He is in wollongong and has this machine which punches out louvres. What a great gig he's got. Saw some of his work and its very well done.
amazer ·
I know hwere you can get it in wollongong.. Vollers. I used to work there. Most larger roofing places that make flashings would probably have it. For what you want, I would ring around scrap metal dealers and cut it with snips.
