type 3 swing to irs
https://forums.aussieveedubbers.com/threads/42821/type-3-swing-to-irs
wrecker67 ·
whats involved in converting a notch with swing axle to irs.
i can feel a subaru conversion coming.....:thumb:thumb
Unbolt the rear trailing arm suspension section and rebolt the IRS one in.
wrecker67 ·
so its just bolt in,and the horns stay there.....
I have a IRS T3 rear end I will swap for the swing if you like ? send me a u2u if interested.
bus914 ·
www.aussieveedubbers.com/forum/viewthread.php?tid=42584
wrecker67 ·
craig you have a u2u,,,i think i have drive shafts from other type 3 i had..is it very hard to pull out.i guess i should get the motor and box out first.....
Sent u2u back................easy to pull out.
The horns are all part of the rear end and come out complete.
Yes you need an IRS box and drive axles
wrecker67 ·
cheers dave,:thumb
bigbaja ·
you lose the horns cause the irs dosnt use horns
so the strongest way for subi conversion would be to use the swing one and irs it
someone was selling one on here a while ago
