\"AB\" 1300 Twin port- what to do?
https://forums.aussieveedubbers.com/threads/42826/ab-1300-twin-port-what-to-do
ctefeh ·
Gurus,
Picked up one of these and after ripping the barrells off and checking end-play, it needs a heap of work. It came with a 30 PICT 2 and SVDA dissy.
So...the current car is a 1600 TP Semi-auto.
What would be the better STOCK option for upgrading this donk to fit said vehicle?
Bore barrells to O/S 1300?
1500 pistons/barrells and re-jet (or use 34 PICT 3)?
1600 pistons/barrels and use the 34 PICT 3?
Ctefeh
1600 if you have the kit, otherwise buy a 1640cc kit which also fits the case without modifying/machining.
You will need to bore out the 1300 heads though to fit, or just buy 1600TP heads.
What is wrong with the engine currently in the car?
ctefeh ·
Craig,
Accelerator pump discharge tube missing from 34 PICT 3, and when I went to change plugs I had to stop myself as the one I tried was extremely tight. It'll either come out after a soak in penetrant or strip itself in which case it's engine out anyway.
Add a 009 that needs a fettle......nothing much apart from that. First kick starter (despite the acc pump!), doesn't blow weed etc.
However, I would rather have something in reserve just in case.
Regards
ctefeh
Special Air Service ·
I have been told 1300 heads have smaller valves than 1600 heads.
SAS
pete wood ·
I had a s/p 1640 with 1300 heads some years back. Had noticably more torque off the lights than the t/p 1640 I had next. Really nice.
