Help: Quick Shift Kit- Gearstick diagram
https://forums.aussieveedubbers.com/threads/42834/help-quick-shift-kit-gearstick-diagram
electricmonk ·
Hi all. Just wondering if anyone had an exploded view of the gear shifter components for a RHD 73 superbug? My daughter decided to play with my carefully arrainged parts and I am not sure which way the plates go. Also I am fitting one of those plstic quick shift kits and wondering how it all fits together. Anyone with a pic would greatly help out here. Thanks people
barls ·
ok the plate with the piece bent down goes in first ie at the bottom with the bent down piece on the left, the quick shift spacer then goes in with. you need to remove the gear knob and top plate. now slide the bush that came with the quick shift down the gear stick and then replace the top plate. now replace the gear stick in to place and bolt down then check for alignment ie you should be able to get all gears easily
Old Dubber ·
http://www.oldbeetle.net/pcat/epc.html
Item 56
barls ·
thats a better pic than mine
http://www.oldbeetle.net/pcat/T1_56.html
Barls.....doesnt this ahow the tab on the right and going up??nn[ Edited on 15-8-2005 by Bizarre ]
barls ·
yeah my bad drugged up on pain killers i knew someone would correct me if i stuffed up
s'cool
i need to pull mine to pieces and do the bushings
I always get concerned which way is up 🤓
electricmonk ·
Thanks very much for the replies. It is very appreciated. I thought I woulddo something easy to start with and things went wrong when I came back outside to find muddy footprints all over the seats and parts in the dirt. You have all helped heaps
