Aussieveedubbers 路 Tech Mods and Frequently asked Questions
harley/rod front indicators in NSW - how legal?
https://forums.aussieveedubbers.com/threads/42869/harleyrod-front-indicators-in-nsw-how-legal
crewcabconnection 路
I've welded up the indicators on my splitter (67), so want to add indicators on the bumper bar - what is the height regulation, how low can they go?
Are there any 'size' regualtions? Amp regs? Can I get a Blue Slip if I stick them in the headlights and not use hot rod ones?
Issue a) it's got a 3" drop front bar and has Indian front end adjustable front end.
Issue b) it's on 15s with 205 60s
Yes I've got an engineers....
pod 路
ask your engineer he should know馃憤
twoguns 路
there is a size issue you will find that you will need to comply too. you might get some one who will let em go thru, but if not then youwill need another solution.
crewcabconnection 路
pod wrote:ask your engineer he should know馃憤
Yeah but I wanted to look stuuupid here first.....lol......der.....darn I should have thought of that...........
barls 路
try ringing the tech support boys at the rta on this number 1300 137 302. they will be able to tell you the rules that apply as they know them
