Hi guys,
Is there somewhere you can point me to where I can buy a speedo cable for a 72 rhd ghia or do you use some non standard one?
Yogie
Kombi_Rescue ·
try this quick fix, you need salvage the clasp at the speedo end and fit it to a standard 1500 beetle cable ..you need to grind the metal flair off cheers dsk steve
ancientbugger ·
I seem to recall type 3 cable was the same length
Yogie ·
Thanks for that guys. I hadn't thought about it until last weekend when I looked under the bonnet and saw a different fitting to the back of the speedo. I had just assumed it was a standard beetle cable I would need. then I realised I hadn't seen RHD ones advertised anywhere.
