For Sale:- A pair early 944 Porsche steel trailing arms and spring plates. The trailing arms look identical to late Superbug and 1976 Beetle arms, but are supposed to be stronger than stock VW arms, they also have an extra hole in the spring plate mounting area, which is used for adjusting toe angle with a special eccentric tool. The wheel bearings are also pretty new. The axle is the same as a VW Thing, they also use Kombi CVs. The spring plates are height adjustable and have an eccentric bolt built in to adjust camber. The chassis will need some slight clearancing for the spring plates, because the height adjustment bolt slightly protrudes. These trailing arms and spring plates will fit all IRS Beetles & Type 3s.
The aluminium backing plates seen in the photo are not included.
$500.00 ono Call Steve on 0413 8111 86 or webmaster@clubvw.org.au Located in Sydney, post code 2210
nn[ Edited on 18-8-2005 by 1303Steve ]nn[ Edited on 22-8-2005 by 1303Steve ]
