VW parts selloff: repost
https://forums.aussieveedubbers.com/threads/42972/vw-parts-selloff-repost
amazer ·
Updated post cos the other got long and messy, and now I know how to play by the rules..
Seller's Name: Chris.
Suburb / Post Code: Warilla NSW (Wollongong)/ 2528
converted semi auto floorpan, rust free. $1000. Pan consists of the ball joint beam with brakes and wheels. The pan itself has manual pedals, clutch tube... unsure if cable is still attached. Rear suspension is complete with std drum brakes and wheels. It is currently sitting under my oval and will need to be lifted before pickup. Its cocooned in the back of the garage so allow 2 weeks. Engine and gearbox not available.
TYPE 3 STUFF (some fit type 1)
windows, front, rear
Window rubbers front and rear. $50 each as new
poly bushes for rear suspension. $40
Whiteline adjustable heavy sway bars 27mm rear, 22mm front. $120 each including all mounting hardware. The rear bar will fit a type 1. The front bar will fit type 3 only and needs to have 2 small plates welded to the front beam for fitting.
1600 engine, excellent runner. $350
Kombi (73 up to t3):
Rear window, 1 piece rear side windows. make offers.
Type 4 Engine:
Standard 2 litre cranks and rods. $240
Hydraulic turbo grind cam, with hyd lifters, used. $200
Heater boxes. $45
General:
Sigma turbo $150
Wheels/Tyres:
2 Dunlop R race tyres $40 pr 205/60/15
4 Yokohama A032R race tyres $200 set 205/60/15
{edit: more info on floorpan and swaybars added.}
{edit: sold items deleted.}
nn[ Edited on 29-8-2005 by amazer ]
karmen ·
the pan got the g/box?
silverbullet ·
could be interested in the swaybars to fit beetle i have type 3 irs rear and bj front. any extra info would be great.
amazer ·
I've updated the original post with more info on the sway bars and floorpan.
The pan is complete and rolling with all four wheels attached. It doesnt come with a motor or gearbox or driveshafts.
The swaybars are whiteline adjustables and come with all mounting hardware except that the front bar needs to have some plates welded to the front beam for fitting and the plates arent included. Easy to make. Just 2 lengths of flat bar about 10mm long with holes tapped in it to bolt the saddles to. The front bar is 22mm and is type 3 only, the rear bar is 27mm and will fit type 1 and 3. Both bars have 3 stiffness adjustments (could be 4, dont remember).
amazer ·
everything is in good condition, id be too embarrassed to sell it otherwise. For independant evaluation talk to Che Castro, I almost gave them away thinking they were 1800's.
ratbug ·
Stub axles modified to run kombi CV's. $80
U2U sent.
amazer ·
a big bounce :bounce
pi22api22a ·
U2U regarding the 1600 engine...
rubyred ·
U2U sent :thumb
-Ryan
amazer ·
tyres have been sold and the proceeds have been spent.
there is the problem of size in shipping a sway bar. They are too big for regular post, and I dont know how to go about doing it any other way. Will look into it shortly.
karmen ·
would the turbo adapt to a 1'5 l golf gld 1979
amazer ·
No sorry, the tuebo would be far too laggy for anything under 2 litre. Even then you would want a pretty agresssive cam to make it function.
pi22api22a ·
Have you still got that 1600 engine? I'm interested.......
Daave
HIT.13R ·
Have you still got the converted semi-auto pan?
amazer ·
Still have both engine and pan. Sorry I havent replied to emails and u2u's but picking a time when I am able to talk on phone is very difficult at the moment.
