Beetle rear wheel track & Type 3 brake Question
https://forums.aussieveedubbers.com/threads/43075/beetle-rear-wheel-track-type-3-brake-question
Special Air Service ·
A couple of questions for you readers.
1) Can anybody tell me what if any difference there is in rear wheel track between BJ/Swing Axle Beetles and BJ/IRS beetles?
2) How much does a Type 3 brake conversion add to the rear wheel track?
I want to buy some new rims but want to make sure they are going to fit in with my current set-up and also the changes I want to make in the future.
SAS
The type 3 brakes make your track a few mm wider. Im pretty sure the track was the same on BG & IRS bugs and numbers quoted by VW would be affected by ET. I have a 1303r in the air at the moment that has a type 3 conversion on the rear, how about I measure drum face to drum face for you?
Steve,
Yeah thats probably what I really need to know ,the difference between that measurement on an IRS Bug & a Swing Axle Bug (if any) as I am trying to determine if 7x16 Fuchs(ET23 I think) will fit under standard gaurds on my swinger and then if they will still fit if I change pans later on. If not I'll have to go 6x16's on all four corners.
SAS
Im sure Jak ran 7x16s Fuchs on the rear of his superbug some time ago, they are now on CTs car.
Measured the distance drum 2 drum on my 1303 which has Type 3 rear drums. Its 1405 mm. Hope that helps.
1303Steve wrote:Im sure Jak ran 7x16s Fuchs on the rear of his superbug some time ago, they are now on CTs car.
I have u2u'd CT and from his information I have decided that if I go with the Fuchs I will be going 6" on all corners as there is a degree of interference with the guard lips that I would have to over-come if I used 7"
Thanks for your help steve
SASnn[ Edited on 30-8-2005 by Special Air Service ]
