T4 2ltr crank
https://forums.aussieveedubbers.com/threads/4308/t4-2ltr-crank
bajaman64 ·
Does anyone know if a 74 or 78mm crankshaft is available for T4 2ltr?
Would be good for some more torque.
Cam ·
There is a set-up called the "powerstroke" made specifically for torque and uses a 78mm crank. This dude sells it, Jake Raby in the U.S.
http://www.aircooledtechnology.com he can be found on shoptalkforums too.
Cam
I would be really interested to know how much one of Jakes cranks are.
Some how i dont think it is going to be cheap 🙁
Che Castro ·
hehe
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=ECR0011&cartid= has some type 4 forged strokers for US$450... not a bad deal considering you can get it with type 1 rod journals and up to 82mm stroke
bugmeister ·
I would recommend buying direct from DMS. My T4 78.4MM with T1 rod journals cost $375 and $50 surface shipping (takes forever to get here though).
I'd research the duty/customs etc. because everytime I try to save a dime by using USPS surface shipping I always get hit with 17% duty, but when I get anything through DHL or UPS (with them acting as a broker) I get 3% "classic car" duty. Maybe you have to get DMS to declare the package as for a '66ish beetle, and also maybe quote the actual duty code. I even thought that surface packages were exempt if under $1000AU but everything I've gotten over around $250AU has been taxed and had duty stamped on (including the *^%*&^ $50 customs fees.
Che Castro ·
wow thats really cheap from DMS for a type 4 crank!
bugmeister ·
US$ BTW.
bajaman64 ·
Thanx for the info. Even in Aussie dollars thats not that bad all things considered.
Time to check the bank balance and call UPS. Looks like party time! :party
type82e ·
theres a guy called hamish selling all new parts to make a 2.3 ltr type 4 might be worth a call
marcel
Un finished projectWILLNOTSEPERATE=$4500
Counterweighted crank, 4"AL finned barrels & pistons, HydXU1 cam, O/S SSvalves Late flange ported & cc'd HEADS with hdty valve springs,new 228mm presure plate and all recprocating parts ballanced
Still requires lifters, gaskets and block.
GENUINE INQUIRIES ONLY!!!!!!!!!!!
ph:0439725589
