Q on fuel pump
https://forums.aussieveedubbers.com/threads/43101/q-on-fuel-pump
72RSbug ·
went to pick up the new fuel line for the EJ20TT and the quy at the shop said I better make sure I have the correct type fuel pump. If the pump keeps working al the time it can burn he told me.
I already have a higp output "Pierburg" electrical pump (also used by VW I was told) but how do I make sure it won't burn up? (maybe I'm getting worried for no reason but just want to be on the safe side)
Does the Subaru ECU maybe have a wire that controls the pump directly?
Baja Wes ·
the guy at the shop is on drugs.
EFI pumps always pump the whole time the engine is running.
72RSbug ·
lol, I doubt that since he was almost 70 years old 🙂
So I just have to hook up the positive wire on the pump to a positive from the ignition (pump on when key is turned over)?
1303 ·
You can hook it up directly if you want to. What type of of ECU are you running?
Most aftermarket and stock ecu's have a dedicated output for the Fuel pump, generally for safety reasons. In short the ECU will stop the fuel pump when there is no trigger signal detected , in case of an accident.
Cheers Paul.
72RSbug ·
I'll be using the stock ecu with a modified wiring loom. I'm expecting it in the mail any day now so haven't been able to check if it has a connection for the fuel pump or not.
