40hp engine mods
https://forums.aussieveedubbers.com/threads/43104/40hp-engine-mods
its63b ·
what engine mods can b done to a 40hp for soem period performance other than extractors?
Adam_C ·
do a search mate...... its been covered.... try searching hottie 1200 or sumthing
pete wood ·
WRX DOHC head conversion 😂
LUFTMEISTER ·
fit a spacer plate and wack on a (good)pict34 carby with its own return spring you will be suprised by the difference 👍
its63b ·
cant find any info by serching,surely someone can help
Grey 57 ·
Check out the 36HP performance mods thread. Pretty much all the same stuff applies. Judsons, Twin carb set ups. Bigger P & C's. There is some cool stuff you can do to these early engines
http://www.aussieveedubbers.com/forum/viewthread.php?tid=43074
yeah look at the 36hp mods except you carnt find bigger Pistons n Barrel kits these have dried up ages ago.
REDKG ·
try samba. big bore kits that bolt on to 1200cc. Mahle 83 mm pistons and barrells.. takes acapacity out to about 1380 cc
