Front discs type 1 with type 3 calipers pcd 120 x5
https://forums.aussieveedubbers.com/threads/43139/front-discs-type-1-with-type-3-calipers-pcd-120-x5
silverbullet ·
I bought these 2 years back now they have only done around a 1000km. I bought the discs new from dba and had them drilled to suit commodore/bmw stud pattern. the reason for selling is that i wanted a set of bigger calipers for the front to even up the braking as i have the eb falcon setup on the rear. So to get new calipers it meant i have to replace the discs as well.
These discs will fit onto ball joint front end and the larger type 3 calipers will bolt onto standard stub axles. uses standard bearings no mods required. New studs would need to be fitted as i had the ones fitted cut down to suit wheel spacers i had fitted.
Good Condition
$350 pair discs and calipers
Tasmania
Buyer to collect or pay postage costs
0418560716 / u2u
Ian
Can organise pics if anyone is interested.
silverbullet ·
bump
