Hello,
I've been having a srange problem with my shifter. When I start up my baja in the morning- foot on cluth, engine running, the shifter doesn't go into gear (I've got one of those T style handle shifters with a button for reverse). I'll force it into 1st and I'll hear a crunching noise as if the engine is engaged but my foot will be on the clutch. Soon as I swith the engine off, the shifter can shift into all gears easily. After switching the engine off and on a few times and jiggling the shifter, I can drive off and the problem won't ooccur again untill the car is stationary for a while. This all started happening when I raised my select-a-drop (my front end is now a little higher than the back)
I did some more testing, and I think the engine may be engaged when I have my foot on the clutch. When forcing the shifter in 1st (foot on clutch & foot off brake) it crunched and move the car a bit. So I'm asuming that the engine is engaing somehow. I suspect it may be the clutch pedal or cable. I don't know if the clutch itself may be the problem. Could it engage the engine?
Thanks,
Nick.
[Edited on 11-3-2003 by Jo Mama]
Jo Mama ·
