trying to work out if its forged or not, do therse numbers mean anything to u?
344376
thanks
sam
dangerous ·
Those mean nothing to me.
Some have say, 82V as in VW rod journals at 82mm stroke.
P means Porsche.
C means Chev rod journals etc.
All on the front counterweight.
Show me a photo and I will tell you if it is cast.
Either way have it Magnetic partical crack tested.
VWFOOL ·
thanks for the info
here is a pic
BiX ·
Mayt the 76 refer to a 76 stroke?
dangerous ·
It looks steel but let me see the front counterweight.
Adolph ·
Looks steel
If jum show us a picture of the crank from the front, or rear, and turn it 90 degrees, so we can see the forging or casting line, I could tell you for sure.
The forge line is about 12mm wide, while the cast line is only about 2mm wide.
