Well, Ive had this VE for a few months now and Im making good progress,
it's a very sound unit and bloody straight with all the bits mostly intact.
A really strong slant 6 and decent mechanicals. Owned by an old Greek couple for eons who loved it, sort of.
Anyway, what is really amazing on this beautiful old beast is the amount of bodgy shit done to it.
Not as bad as a car that had been owned by 25 backyard bodgers like say an old torana or Charger but bodgy nonetheless.
When I got it the amount of cleaning up needed was obvious, the thing looked terrible and it looked rusty but it wasnt. Con decided to preserve the old girl by drowning it in fishoil. He poured the stuff everywhere, into every door jam, chrome strips, roof gutter, all over the place.
Gotta sand it all back and wirebrush and sand, and sand some more.
A respray is the only option, Im well into that already.
The two mirrors are both different and the left one was half held on with Liquid Nails ! WTF!!
Silastic! The thing is full of silastic or silicon gel acting as a loctite on chrome strips which should be using clips not ground down 3/16 screws and nuts. The silastic is holding on the letters and just about anything else
that could rattle loose. Been cleaning the stuff off for days.
Bottom radiator hose had plastic strapping and fencing wire pulling it out of the way of the fan belt which was running very close to it???
Turns out the hose was on backwards and just needed to be turned around in order to run behind the fan belt with heaps of room. I laughed at that one.
Heater stopped working so they left heater hoses running to nowhere in the engine bay and put bodgy taps in the hoses to stop the coolant loss.
I fixed all that up today, the demister ducting under the dashboard was a combination of radiator hose, pvc plumbing pipe and shitloads of silastic holding it all together. What a mess. Lots of messy wiring and yellow insulation tape too. They could have at least used black tape!
Had to clean that up before I installed the DVD anyway, all fixed now.
Battery leads I had to replace, the originals were either too short and/or too weak and the super neat job I did on the whole power supply including cleaning up years of acid and rust looks great. New terminals and heavier leads helps it to kick over with a vengeance now.
The wheel bearings were stuffed. $50 and a few beers later they were done. Needed tyres too. and wheel alighnment. I lowred the front and it has that great stance now.
Numerous other little bodgies I have fixed and no doubt I'll find more.
What have you found in your old cars as you took on the rebuild and restoration stage? Any serious dangerous bodgies?
sax ·
