if i wanted IRS, disk brakes all round and wide 5 stud pattern on a beetle pan, whats the best option to start with?
jnr356 ·
68 auto pan?
your wide 5 discs all round are going to blow the budget
ruckus ·
What about a super pan, butchered for balljoint framehead and wide 5 drums instead. It'd be a hell of a lot cheaper.
akean1 ·
its a long term thing, so expensive is ok, just have to save for the dear parts.
are there many 68 auto pans around? i was thinking of a 1970 as id have to change the stud pattern anyway.
do 68 auto's have disk on the front ?
68 or so semi auto pan, or a 76 model and u will have to get adaptors to make it wide 5 again.
ruckus ·
They're not all that easy to come by but they are around. I'm getting mine from SA, but there have been a few on ebay lately.
vw2b ·
Just go with any Ball Joint Pan then get it changed over to IRS. Will work out about the same cost wise and then you can get heavier pivot box's and stuff
Steer clear of king & link front ends. 72 and earlier pans generally have less RTA / Vic roads restrictions than later pans.
akean1 ·
sounds like semi auto (are they all balljoint?) is the go, thanks for everyone's input:beernn[ Edited on 31-8-2005 by akean1 ]
ruckus ·
Yup, all bj/irs. You'll have to put a clutch tube in, unless you're lucky and it's already been done. I was going to bring one down from Albury with killakornkobb (Damien) as he was interested in the gearbox. It was going to be fairly cheap (other than the shipping) but it's not available until November now I think. Are you interested in it?
akean1 ·
yes! should have some funds by then, let me know👍
killakornkobb ·
im still up for going halvsies too 🙂
ruckus ·
Akean I forwarded you a few u2us. 'david' is the guy in Albury. Not sure if he still has it though.
akean1 ·
killakornkobb wrote:im still up for going halvsies too 🙂
what parts were you after? i pretty much just want the pan, beam, and gear box
killakornkobb ·
was just after all the semi-auto gear... for a spare, and poss the starter if it's there
