sunroof photo for nbturbo
https://forums.aussieveedubbers.com/threads/43358/sunroof-photo-for-nbturbo
jaksc ·
Hope this photo of the sunroof open is what you were after. Let us know if you need any more help
ruckus ·
Is that as far as they go?
jaksc ·
it opens a little bit further than that but does not completely slide back underneath itself
nbturbo ·
Thanks very much for doing that for me.If at all possible-would like to also see how they join the seal at the back corners-the seal across the rear lip is a separate piece to the 2 sides and the front.I was afraid that it might go on the body and not the sunroof.Will be a lot harder to attach.If it glued to the sunroof-it could be clamped and stretched then held in place with some timber strips while the glue dries.Again many thanks for the pic.Gary
jaksc ·
the seal is stuck to the body. we used contact cement but you only get one go at it using this method
