I have a set of 5 VW T3 Syncro wheels, these are like stock Kombi rims only wider. $250.00 the lot, 4 with tyres mounted.
4 x chrome 15 x 6 steel rims early 5 stud , suit splitty or Beetle, $150.00.
Plus I have loads of other stuff, including Kombi and Beetle seats , body panels, Beetle, T3, Kombi.
Let me know what you need, If I have it, I'll bring it. I need to clean out, so prices will be cheap too!!
karmann_kombi ·
Hey do you have a stock 2 litre kombi dizzy
Menangler ·
Single vac advance or dual?
I have a single Vac advance one, I will bring it.
karmann_kombi ·
not sure dave i am new into kombis and just know the 009 is wrong for the motor as i have flat spots. Maybe some else can help out . I really need the correct one and would rather not buy it if im not 100% sure
Menangler ·
Up to '77 single Vac dizzy, after is dual, although both will work better than a 009!
Not many Kombi's run the dual Vac advance as they are a the polution gear dizzy and timing is set to 10 deg after TDC.
steve-89 ·
do you have a type 3 moustache.
u2u you me if you do, and also the long chrome reflecters for the back guards if you have any.
cheers steve
vw59 ·
Hi Dave,
Do you have any brackets to mount inertia reel seat belts in the front of a Kombi? And after a front splash plate for the front of a 68-70 kombi that shields the cables and pedal assembly from water?
Thanks Leigh
ringoschariot ·
You have u2u re early chrome rims
ColumBUS ·
wouldnt have any solex carbies would ya?
hypo-vw ·
Hi Dave , would you have a healthy 2-litre kombi gearbox ? need one for a customer that cant afford to repair his own .
Menangler ·
Sorry I don't have one at the moment, There was a cheap one on Ebay last week, it is finished now, think it went for under $200.00 Doh!
