70AutoStik wrote:If that don't work, check your brushes (and commutator) - if they are in poor condition, the increase in speed could cause them to lose effective contact.
If the brushes look sick, but are of a good length, you can clean them up on a bit of sandpaper. The commutator can also be cleaned up with fine sandpaper, but you need to ensure the insulation material between the pads is below the outer surface (or they'll lift the brushes
I'm not trying to be pedantic here, but since he has an alternator he doesn't have a comutator - he has slip rings.
Alternators work "inside out" compared to generators - the spining part carries the low current field windings (via small brushes and smooth slip rings) and the fixed outer windings provide the charging current.
Alternator brushes take a long time to wear out as they are running on smooth slip rings and so don't spark like the generator comutator does.
Still worth checking though.
The 75 alternator has an internal regulator, so should have just two connections on it - a thick red one direct to the battery, and a thinner one (probably blue) to the dash light. It is interanlly earthed, so there is no erth wire, but as other have said above, the earth straps for the battery and tranny must be in good condition or weird things happen to the electrics.
The dash light MUST work for the alternator to charge - if the bulb blows, the alternator looses it's "sensor" current and won't charge.
