my baja in the bush.
https://forums.aussieveedubbers.com/threads/43500/my-baja-in-the-bush
Anthiron 路
71superbug 路
mmmmmm that looks so much fun? one question..what motor do you run behind it?
is a 1600twin port enough to have some decent fun off road, dunes, beach .etc?
just curious as i have a 1641 sitting around in pieces that could do with a good use.
Anthony馃シ
64vwmark 路
Great to see a Baja doing what it was built for.....:thumb
As for the 1600 71 superbug, I've seen quite a few 1600's off road and they do very well, in fact one day we showed some v8 hiluxes how it was done!
Anthiron 路
its got a 1600 single port engine in it. goes quite well but lacks that put ur foot down grunt with the 31's on the back.
Doug Sweetman 路
My old red baja had a 1600 single in it at one stage too, absolutely bulletproof motor, I caned it for 4 years and couldnt hurt it at all. I remember driving it back from Kalgoorlie to Perth one time (about 600km) into a corker of a storm, about 50kmh headwind, the most I could get it to sit on was about 80 - 85kmh 馃檪 I had 31's on the rear too.
Very nice photo too by the way - nothing like baja's in their native territory
Anthiron 路
heres another from the same place
Doug Sweetman 路
Do your rear tires rub on those guards much ?
Anthiron 路
not on the guards but because they are actually the fronts of the set (the rears have to big of an offset and wont fit till the wide guards go on) they rub on the spring plates during suspension drop which shits me to tears!
ColumBUS 路
when you get some fat guards, a bit more lift and a meaner engine, come and see me ive got a set of fat baja claws here that would love to sit under your beast.
Doug Sweetman 路
31's are just a bit too big under a std swinger bug without lifting it at least half a spline. IF you dont mind me hijacking, here is a photo of my late 57 baja that I had for a couple of years - before we lifted the rear. Tyres rubbed like a bastard before, and werent a problem after...
Anthiron 路
if i jack up the rear with the current wheels on it it will just cause them to rub more on the spring plates......i am having no issues with them hitting the guards.
ps ur baja has the same kit as mine:thumb
Ellabella 路
wat offset wheels have you got??? i had 33's on my last one for like a day... never hit the sprin\g plate........ smashed up the guards tho. are you running the longer axle/axle tubes????
Anthiron 路
they are front offset. dont know what the backspace is exactly. the other ones are the right offset but will stick out too much for the skinny guards so when ive done the glass work on the wide guards they will be put on and should fit fine.
33's are illegal on a bug. i only want 31's anyway. but i can see why they would rip your guards up. they are big tyres to have under a stock height baja bug.
Doug Sweetman 路
I can see why that would happen with the front offset on the rear. I had the 15 x 7 rims made for the back of that car (I sold it in 2003, silly me - now I am building another Baja !), and yeah, once it was raised it was sweet.
I reckon the bug eye kits are the best, but the one I have now has the Cheetah kit (wide eye with the bonnet scoops), I think I will have to make some bar work to mount the lights off, the guards have cracked as it is with that much weight hanging off of them.
33's would be huge on a bug ! I didnt realise that 31's were actually legal - I have been thinking about what rims and tyres I need for the car....
Anthiron 路
i reckon 15 inch pecos all round is the best setup for a baja or buggie. nice and strong and simple. or if u cant get that then wide stockies dont look too bad if they are clean and painted.
who can afford centerlines? pffft
Doug Sweetman 路
Yeah, peco's or Sunraysia's as we call em over here in WA. I know a place over here who can make them any size, 14 - 17"....
Anthiron 路
sunraysias are a bit different 2 peco stars arent they?
Doug Sweetman 路
Umm yeah I think Peco's have the straight spokes and sunraysia's have the angled spokes ? truly I dont really know.
karmen 路
anth can ya take a pic of how the bar work fits at the back mine is att to the shockies but nothing else and the thing sags.
am restoring it i think it is 1300 has big wheels but for road i will carry stock wides to put on the back as i have to drive 80ks to get to Tin Can
DubCrazy 路
go the wide stock rims ... Yummy!!!! oh have to get them powder coated tho......
steff...........
Ellabella 路
lasti checked you could legally put 29's on..... i think it was the cheeta kit i had...
Anthiron 路
my cage bolts around the torsion tube underneath and then the 2 main bars come up and over the engine and bolt thru the firewall. not quite as well secured as if they were attached to the shock mounts but it has a cross bar for strength.
Anthiron 路
oh and for long distance driving the bigger the wheel diameter the less fuel u will use. just take it easy getting up to speed with a 1300 or u will be labouring the engine trying to gun it.
theres how my bar work attaches to the torsion tube.
this lower attachment works well and is much stronger than the bottom shock mounts but the upper attachment goes thru the firewall. which is pretty thin. so u want the 2 upper main bars to attach to the upper shock mounts on the rear which gives u better engine access as well.
Nick
