I have an 82mm x 94mm engine that has just been freshened and will be sold with or w/o carbs, it has a brazillian case , scat wedge-mated crank with J&G clutch set up , Rimco super rods , 10.3:1 comp new rings & honed barrells , Berg 319a cam , straight cut gears , 28mm oil pump and full flow cover , new bearings , your choice of new scat ratio rockers , A.J. Sims wedge ported heads with 42 x 37.5 mm stainless valves(just cut) new springs and 1 5/8 merged exaught , $ 3600 or with 48ida pro stacks , 42mm venturies for $ 4900 . ROD 02-42729920
dragbug ·
Couldnt build it for half that!!!
A true bargain,
Carn stevie....stick this in the back of your notch!
Turbo54 ·
You should buy it Aaron, you'll need it with that big turbo you've got!
T54
BiX ·
Any idea on possible power and also what did it come out of?
2443TT ·
I'd estimate an easy 200HP at 6000 RPM.
mountainbug ·
Is is possible you could convert this for a street (daily driver) set up??
thanks
vwkid ·
yer, what mountainbug said,
MOUNTAINBUG: maybe we can cut the engine in 2 and share its hp and price? i bags the right hand side!
ps. how big r u mountainbug?
StenGuns ·
Rod.. Check U2U
vwkid ·
sorry dude.
I am interested as I have already sent rod a u2u, although have not as yet received a reply.
It's hard to show further interest with the intent to purchase while many questions go unanswered.
maybe you could be rod's secretary? how do u look in a skirt?
RodPenrose ·
This is the first of about 12-13 engines that I have plenty of new and used components for , that I will put together as I am cleaning up and need to make some more space , This engine has no rocker gear attached as yet and could be used for a quick streeter using std ratio rockers producing around 170 hp , or by using 1.4 ratio would give you an extra 30-35 hp , however this becomes a not so driver friendly deal if used on the street . I hope this info helps and keep a look out for the next couple of engines , ROD.
