well it's a magnetic clutch of some sort, looks like it's off an air-con compressor, or a Toyota blower. Come on, what is it?
Alex Holzl ·
none is gonna post a reply here coz they dont wanna admit to being old blokes!! 😂😂
Alex
lugnuts ·
pete wood wrote:well it's a magnetic clutch of some sort, looks like it's off an air-con compressor, or a Toyota blower. Come on, what is it?
The first part is spot on,dont know what its off,only know what its for :kissnn[ Edited on 13-9-2005 by lugnuts ]
lugnuts ·
Alex Holzl wrote:none is gonna post a reply here coz they dont wanna admit to being old blokes!! 😂😂
Alex
DAVE !!!!!!!!!!!:thumb
dangerous ·
Electro magnetic clutch for a Norman Blower?
Go jump Alex :cussing
Alex Holzl ·
good one barry you posted and now everyone gonna think you got it easy with cheap public transport fairs!!
Alex
lugnuts ·
Its a clutch pulley,supposed to slip at 4000rpm for drag racers,instead of takin the belt off,OR SO THEY SAY :P
cant you just put more shims between the halves???
I think the clutch pulley "might" just look a tad mmore suspicious???
I aint THAT old Alex!........... :kiss
tassupervee ·
Now that sounds very suss. I think someone may be pulling your chain there.
I would say its used to simply disconnect the fan/alternator/water pump/whatever altogether for the duration of the run.
Them clutches take a very, very dim view to any slippage at all.
Witness the damage to the plates when an Aircon compressor seizes and the clutch stays pulled in. At best, they simply flick the belt off, worse break the belt or at worst, they spin the clutch plate on the tapered shaft, shearing off the key.
Very messy!
Ill believe it when I see it running and slipping away@ 4 grand!
L8tr
E
