Anyone know how to remove the heater funnel in the front cab of a splitty??
I am trying to get to the back of the front nose panel to do a bit of panel beating ???
Is it welded in there? anyone got any idea hoe to remove it!?!?!
Dozza
nicko ·
Its welded in Dozza
Dozza ·
Thanks Nicko,
So I guess I have to grind the weld and then put it back after.....
Dozza
Dozza ·
problem is,.... some of the welds are round the back!
59 BUS ·
Cut the nose off to grind the heater funnel welds, then weld the nose back in fix up nose, cut nose off to weld heater funnel back in, weld nose back in then work out how to fix nose with heater funnel in the way. Doh!
Dozza ·
errrhhhh??
I dont think I will take that last post to seriourlsy!!!🤪
nicko ·
I read something recently on the samba about using pump up balls - soccer balls footballs etc to pop dents out from confined places like where you are talking about. You put the ball in flat or partially deflated and then inflate until the dent is pushed out. Obviously wont do everything but could be of soem help.
Nicko
Dozza ·
Nice one Nicko, like the theory.... might well give it a go.....
