My 40HP is running on when it's hot/at operating temp. Here are what the plugs look like. The runnin-on seemed to happen when i started using ULP (as opposed to PULP) cyclinder's #1 and #3 seem a bit lean, though #2 & #4 look pretty spot on. So there would not be any bits of carbon etc that would be 'dieseling' the engine when i turn it off. Also, when the engine does stop kicking over when i turn off the ignition, it stops with a bit of a clunk and very abruptly.
help?
What is your timing set at??
Try PULP again and see if it stops??
Do you have any idea what the compression ratio was set at??
oval TOFU ·
some of these shot were taken in the shade so you can see the difference...nn[ Edited on 22-9-05 by oval TOFU ]
oval TOFU ·
timing's at10 degrees BTDC..
yeh, I'll fill up with PULP next tank... no idea what the compression's at... i know it's got good compression though..
EgeWorks ·
From what I've read (I'm not expert) running on can be caused by two things. One is too lean, the motor is too hot and the heat will detonate fuel after the plugs stop firing. And two, if it's too rich, the carbon buildup can heat up to the point where it will detonate fuel after the plugs have stopped firing.
Given that you are using a lower octane fuel, which causes the engine to run leaner, my guess is that it's running hot...
Like I said before, I'm no expert and am probably wrong here🙂
Menangler ·
I would set the timing at 7.5 BTDC and go back to premium
Kombi_Rescue ·
I am with dave on this one ...too far advanced knock it back to what dave said 7.5 and run pulp..cheers steve
kombipom ·
Same thing happend to me when I first filled up with ULP, the octane rating was too low, I just went back to PULP and it's been OK.
oval TOFU ·
cool (no pun intended) I gave my enriched mixture by 1/4 of a turn but it still ran on.. so the next tank will be PULP - sigh.. and these things are supposed to be frugal and cheap to run!
Thanks for the advices peoples! This community rocks my jocks
What does pinging sound like? A high pitched tapping noise when you apply the gas pedal? (kinda sounds like a small bolt rattling?)nn[ Edited on 22-9-05 by oval TOFU ]
yes
"usually" under load.
a marble in a glass jar.
a loose exhaust system
Stand on any corner and wait till some one comes along in a Lancer or Magna (dunno why - these cars almost ALWAYS do it :jesus ) you will see them slow and then try to accelerate in top or 3rd.
THAT is the noise
Grey 57 ·
Yep thats what pinging ssounds like Chris. Not good.
Optimax is the key to a sweet running Volksie motor in my humble opinion.
PrettyBlueBug ·
Now I think of it..... I've used ULP the last 2 tanks, and my carby had a spazz...?
oval TOFU ·
yeh PBB, sounds like our running cost just jumped another 10c per liter!
oval TOFU ·
hows ya bug btw?
tassupervee ·
Men
You need to know and understand that no amount of ignition timing changes will affect run-on or deiseling to any extent.
The bloody ignition is switched OFF. Hell, pull the plug leads and the thing will sit there clanging away!!!
Altering timing from near standard results in loss of performance or at worst detonation which further promotes the heat buildup. WOFTAM!
The engine is suffering from auto-ignition (Deiseling)and you could adjust the timing to 100 degrees BTDC but them plugs just dont spark after the key is off so forget that.
Deiseling is caused by local hot spots in the combustion chambers, often from coke left over from the combustion of oil and plenty of other factors. This coke buildup can glow red hot and ignite incoming fuel.
Enrichening the idle mixture often PROMOTES deiseling.
The best strategy is to lift the heads and decoke it and look for any sharp edges in the combustion chambers and lightly blend them out.
Another strategy worth investigating is what Ford employed in 1600 Escorts that suffered pretty badly from deiseling. They fitted a solenoid air valve that vents the inlet manifold to atmosphere (via a small filter) when the ignition is turned off.
This way, little fuel can be drawn into the engine on shutdown and the engine dies pretty much straight away.
The system is characterised by a hissing when the ignition is switched off.
Again, you can frig with your ignition timing until the cows come home but you will NOT solve your problem completely. Fueling up the idle mixture will simply exacerbate the problem. You DONT want fuel in there to be ignited.
You either live with it and kill it with the clutch or deal with the problem by decoking it or fitting a vent valve.
Good luck.
L8tr
E
L8tr
Enn[ Edited on 22/9/05 by tassupervee ]
PrettyBlueBug ·
oval TOFU wrote:yeh PBB, sounds like our running cost just jumped another 10c per liter!
Yeah... d'oh!! 🥲
I find out about my Bug tomorrow... keep your fingers crossed it's not too bad! :duh
oval TOFU ·
tassupervee wrote:Enrichening the idle mixture often PROMOTES deiseling.
L8tr
Yeh I know, but I was thinking that perhaps it was running too hot and therefore heating up some coke or sharp edges that normally wouldn't diesel after there's no spark. But anyways, I'll be using PULP agian and I'll see what happens..
Should I go 10 BTDC or 7.5 then?
Kombi Dad ·
I have also experienced running on occassionly in my Pobjoy 1380 in the '63 single cab. One of the dealers in Canberra advised to go to a higher octane unleaded and that should fix it. I still run ULP and have not changed as it does not do it too often.
Yes Tasssupervee is right the run on is caused by coke in the heads.
Adjust the timing and use PULP try Optimax. I have a dunnger old 1500 single port in my car and what ever crap they out in the Optimax it cleans the inlet up in no time, so it will probally clean the combustion chamber in a few weeks.
I would check to make sure you have all the correct tinware fitted and that the engine is running and being cooled correctly as extra heat will add to your problems
What size main jet do you have fitted as well. If its too small then the engine will run lean and cause overheating as well. You may have to increase the size of the main jet as well adjusting the idel screw will only richen the mixture at Idel not under power
General_Failure ·
Is your cutout solenoid working properly? I agree with everyone elses diagnosis of the problem though. had the problem myself. That what when I experimented with LRP.
oval TOFU ·
I've changed the timing to 7.5 and I'll be running PULP again as soon as my tank gets low enough. Do I have to go for 98RON? I was previously using 95 without any probs, so logic would tell me to go back to what was working yeh?
My tinware is all saavy. I had replaced the front and rear seals and made sure the tinware is pretty tight.
I'm running a 30PICt-2 carb - I have no idea what size jet I've got - how can I tell?
Menangler ·
95 will be fine,
And Tassupervee,The timing does make a difference, if you run your timing too far advanced, up goes you combustion chamber temps, and thats is what promotes detonation.
I know the spark plugs don't fire with the ignition off!!
tassupervee ·
Not necessarily! And Im not going to bother with an explaination. Look it up. google is your friend!
But, whatever, bottom line is the combustion chambers have hot spots causing auto-ignition and any magic carb/ignition adjustments will have precious little lasting effect other than to reduce performance and economy and there is not enough spare performance to comfortably loose in a kraut.
Either live with it or fix it properly, and forget all the bandaid wives tales.
L8tr
E
plough ·
PULP fixed my the runnin on in my vw, and also made it run a bit sweeter, a bot more expensive but u have to live with that or start walkin
oval TOFU ·
Well, I've chucked in PULP and retarded the timing to 7.5, and it's made a lot of difference - running on is only one or two cylinder expansions (if ya know what I mean). So I'm going to run Optimax in the next tank to really clean out the remaining crap thats causing the run-on... should probably clean my plugs a bit too..
hmmmm.......google
ok
a few things that have not been mentioned.
A high idle speed
Spark plugs the wrong temp range. eg BP6HS
Shut off solenoid not working
most sites confirmed heat as the main culprit - caused by lean fuel, low octain, timing and carbon build up.
All the sites i looked at said there would be a sufficient build up of carbon to cause hot spots if the other factors mentioned (timing etc) were present.
Food for thought
Barry
oval TOFU ·
ok
My idle's fine and smooth
My spark plugs are in the correct heat range - those Bosch one - W8AC or whatever
Does a 30PICT-2 have a shut off solenoid?
If when I change my plugs and it still runs on a tiny bit - how do I get rid of the exsisting coke in the cylinders? (theoretically speaking - I'm going to run a tank of Optimax to see if that'll clean it up first)
tassupervee ·
Optimax will NOT remove carbo deposits in the combustion chambers.
As far as a stock Veedub engine is concerned, the only thing special about Optimax is the price.
There are quite a few methods of removing carbon ranging from high concentrations of Caltex Techron fuel additive to revving the engine up and pouring in water into the carb, not enough to stop the engine mind you!.
To varying degrees, some of them work, but nothing works like lifting the heads and adding elbow grease.
Its as simple as that.
L8tr
E
Adolph ·
I agree with most of you but
I think your comp ratio is high and that is the reason why you were suppose to run PULP. If it was just the carbon, cleaning it will only help until it builds up again.
The other reason for me saying it is high comp. is because you mentioned pinging, and you described it spot on, and that together with the lower octane ULP and dieseling points to high comp. ratio.
I would say, run PULP and timing 7,5 degrees (to be on the safe side with the pinging).
You could fit a idle cut off solinoid in place of your standard idle jet, it gets power from your + terminal on your coil.
Hermann
Anthiron ·
yes your carby has a shut off solinoid.
its on the right hand side. (facing the engine) there should be a wire coming to it and the auto choke. the shut off solinoid is a short cylinder.
turn on your ignition and undo the wire from the solinoid and then touch it to the terminal a few times. u should hear a clicking sound. this means its working.
mine runs on occasionally. if its poorly tuned or if im forced to run shitty fuel. usually i run it on optimax and its fine.
Kombi Dad ·
I finally changed to PULP and found that fuel consumption went from about 10l / 100km to 8.0l / 100km. Would appear using PULP helps the 1380 to run a lot better. The figures quoted were on a trip from Canberra to Lismore and back just recently. I do not have the running on problem any more.
oval TOFU ·
Anthiron wrote:yes your carby has a shut off solinoid.
Isn't that usually on the rear or the carby (looking at the engine)? I don't seem to have one anyways- I only have an auto choke it seems.
UPDATE After a couple 90 min drives on the freeway on RON 95, I get no more run on, nor pinging. I do get a bit of a flat spot on acceleration, so I'll be tuning it back to 10 degrees BTDC and see how it goes..
GO PULP!!!
Amazing what a little Octane will do for your engine
56astro ·
Are these run-on problems only experienced in small, original size valved heads?
I have this problem and am getting a little worried that continually stalling the engine with the clutch and brake might be doing some harm in the long run.
I ran quite a few tanks of BP Ultimate through it and didn't seem to make any difference.
Other than using expensive fuels, I was contemplating:
1. fitting 40x35 valved heads
2. ditching the Kads for some small-ish IDFs
karmen ·
what about a good country drive to decoke.
like after an hr of steady cruisin in wth (5th if ya got)
then drive on say 90ks nahre 4 5 mins in 3rd without flooring it.
m
ercedes manual says this way u can clean spark plugs etc.
I changed my timing to run my Seat GLX on ulp due to budget (6 cars) and no pinging and its on 244.000 ks and i changed it 110,000 ago when i got it off my rich son (PULP only) they did not have PULP or 98 octane in the ole days. guess the lead had somethin to do wid it too.
then there are additives for the fuel (upper cyl lube) and TEFLON
woah there 40 horses....
need any oval stuff....found a shed full in Bundy Tofu ...incl mint? 54
karmen ·
thats 9o kph for 4 to 5 mins on flattisch road (not steep hilly rd)above sorry
oh yes had no work done iexcept clutch at 200 Gs !!
karmen ·
shut off valve came in 68 beetles etc not orig 40 hp.
want one ??
Try BP Ultimate - I had constant pinging/etc (even with a knock-sensed HSV) with Optimax
I have heard several people complain about run on with Kads.
Baja Wes said he had it with his Kadd'ed 1916
Are you sure your timing / valves etc etc is all ok??
Dont you have a Pobjoy Astro??
What does Stan say??
Does it get hot??
I reckon you would be better with a set of IDF 40 or 44's.
IDF 36s would be too small
[ Edited on 26-11-2005 by Bizarre ]
56astro ·
I don't have points so I set the timing at 28-30 @ 3500.
Valves have been done and there was no difference between before and after.
Yes it is a base Pobjoy, it has done it since new. Stan knows it does it. When I rocked up to his place after I got it back on the road it did it in front of him.
He puts it down to the Kads, which I got 2nd hand and supplied to him.
It's never got hotter than about 125 deg C and hasn't been hotter than 110 deg C since the rebuild. I do over 100km to work and over 100km return, so it does get a really good run.
I got IDF44's for the mean time (steroids planned) do you reckon they might be too big for the small-valved base version?? Maybe just a change in vents and jets??
56astro wrote:I got IDF44's for the mean time (steroids planned) do you reckon they might be too big for the small-valved base version?? Maybe just a change in vents and jets??
AC.net recommend 32 vents for 1600's (see above link) - and i agree (what ever that means :P)
I ran my IDF 36's with 32 vents on a 1600 and they were sweet as. On the 1776 they needed nursing. Just never seemed happy.
Reckon they needed 34 vents - but i couldnt be put in. Should have bought 40's or 44's
I know several 1916's with stock 040 heads motors that run 44's
