VP V6 into Kombi
https://forums.aussieveedubbers.com/threads/44129/vp-v6-into-kombi
jeremy ·
Hi all,
I have a 77 micro bus and was wanting to perform a V6 engine conversion.
That all the heaps on info on this forum about engine conversions but I have a question about the legal side.
I hear about people getting an Engineers Certificate is this the same as a modification plate?
From experience with a V6 conversion what other items required modifiy? eg brakes
thanks
HotRodMatt ·
Depends on the state in which you are registering it. NSW will need an engineer to certify the modifications.
wacked1 ·
All this stuff has to be changed
Accelerator cable, fuel tank must be EFI, adaptor to suit V6 motor to kombi box and flywheel. Prefer 2L transaxle, wiring , radiator and plumbing, crossmember has to be custom made, exhaust, you shouldn’t have to worry about brake upgrade, I had a V8 and it pulled up fine. If you need any more info email me v8kombi@yahoo.com.au
Wacked1
HotRodMatt wrote:Depends on the state in which you are registering it. NSW will need an engineer to certify the modifications.
ALL states will need certifying.
Might be best to talk to a shop that has done this before and can do drive-in, drive-out conversion for you. There are one or two around Sydney
jeremy ·
what does this mean?
who does this ?
what is envolved?
Is this like a modification plate
I am in QLD
pete wood ·
Ring the Qld dept of transportation. Talk to the tech people. They'll tell you how to do it. They'll also give you a list names and numbers to call. Basically, a motoring professional looks at it, says what needs to be done, you do it and it gets certified. It can cost between $300-1000 approx (don't quote me).
crewcabconnection ·
why VP? not later? - get a blower....vvvvrrrrrrrrrrrrrrrrrruuuuuuuuuuussssssssssshhhhhhoooooooooommmmmm
jeremy ·
I currently have a VP engine complete with computer, wiring and fuel pump sitting on the garage floor. I brought a complete the setup for the auto box, but now I see a new idea forming
V6 + Kombi = Lotsa Fun
who does this ?
what is envolved?
I am in QLD
What: 'Certifying' means the vehicle will have to be checked and approved by a 'Recognised Engineering Signatory' (aka 'engineered') to allow it to be registered after it is modified. This engineer dude will make sure all the components used for the modifications (such as new engine mounts or crossmembers) are safe and sound and that the vehicle's brakes can match the engine's performance and that its emissions and noise levels are withing Government limits
Who: An recognoised enginering signatory - get detaisl from the rego office
Yes, it's a mod plate.
vwtyp2 ·
Transport S.A. never asked me to uprate my brakes.
I needed to change the fuel filler neck to ULP type.
Catalytic converter.
Emissions test.
No modifications to engine to increase torque or power. ( it doesn't need any, although the guy I sold it to is fitting one of the CRS blower kits)
Report from engineer on structural beaming, lane change test, and brake test.
as stated before, all this will depend on what state you're in.
