I just got word that the All Motor Speed Record is mine at 112.64....Yeeee-Haaaa!
Craig Paton 路
Cool!!! All ya gota do now is get the et record as well! :thumb
Hardly a challenge!馃榿
Congrats Dave
nn[ Edited on 23-9-2005 by Craig Paton ]
Stanley 路
Onya Dave...good to see you sticking it up those ricers....well done
hypo-vw 路
AWSOME!!! ....well done Dave , keep up the good work flying the VW flag high for all of us . Hope you get that ET record soon . Wayne .
:beer
HS618 路
Hard work always pays off and is reflected in achievements - Congratulations Dave, excellent result!!!!
Now, the thoughts in your head start - "one more tenth, one more MPH". Good Luck!!
jvl054 路
:bounce:thumb:beerJVLRacing:P
reub 路
Congrats mate :thumb
Dasdubber 路
Fantastic work Dave - fingers crossed for that next milestone!
Buggyboy 路
Firstly congratulations, but can you tell me what this means, was it a specific race meet or something..
Dak-A-Tak 路
GOOD-ONE DAVE,from DAK-A-TAK, 48IDA, Hope the Honda guys go back to pro front wheel drive real soon. ( us two)
Boostn 路
Your the man !
N/A wow!
dangerous 路
Thank you every one for the positive comments!
The old record was 105.77mph.
ANDRA records can only be set at designated meetings, of which
there are only two up here at Willowbank in the year.
You must produce two runs under the record,
and one of those must be in eliminations.
There are some other technicalities, but in general the runs
must be within 1% of each other.
Also the minimum weight for this class (ALL MOTOR) the
car must weigh more than 795kg and my car was 820 on the day.
kroozzn63 路
go Dave well done ,dont think weve met but congrats on your win ,watchin those drags opened my eyes on how technical it is you must have nerves of steel.
twoguns 路
good on ya dave. congrats mate. sounds like youre really enjoying it too!:thumb
humpty 路
Rock'n'Roll Dave....Damn good news......Now you'll be wanting to push the margin further!
He, he!
Bug_racer 路
Congrats , hopefully next time you'll have the et as well as the speed . Good luck and keep up the good work .
Fossil 路
congratulations :thumb
Bug_racer 路
Since the forum has moved to a different server and the Post " the dave butler story " is gone I thought I'd post it up here . Im still curious about your dual supercharger set up , especially on the 1776 motor .
What convinced you to run dual superchargers ? Whas it a steep learning curve ? How did you stop the head studs from pulling out ? How much boost were you running ?
dangerous 路
I only ever ran one supercharger on my 1775cc engine
and it was an old and inefficient Godfrey roots style thing.
It still had 28psi though.
Still using the same blower and over drive I progressed up
in size over a five year period to 2918cc(101.6x90) still
type 1 but with Pauter case.
It was at this point with only 15psi (10.2's) that I bought
the two Autorotor blowers. At the time I couldn't
purchase one unit that was large enough for my plans.
This combo with 42psi and 10:1 was a Carrillo breaker.
Anyhow I went to a 2827cc combo with AF bugpack
heads, and in that trim it ran 9.76@146.9mph.
In the tube car I did run 2965cc with Pauter case and
heads, but never got a full power pass. 6.19@116 on
the 1/8 milewas its best.
With correct tuning to prevent detonation, the headstuds will stay put.
Yes, the learning curve was steep and expensive, but an experience worth every cent.
The project was madness!
Bug_racer 路
I'll buy you a beer next time your in Sydney . You got courage to run such boost on an aircooled engine .
How did you work out your ignition timing ?
How much fuel did it use ? What carby / injection did you use ? How did you seal the barrels onto the heads ?
dangerous 路
Through trial and error I ended up with 24 degrees total timing. Would prob run less now.
It used about 8 litres of methanol per run.
I used mechanical injection which I flow
tested using a milling machine's variable
spindle speed.(driving the pump).
It flowed 3litres in 10sec @ 7000rpm.
The barrels are held onto the heads with 10mm
studs of 4340material.There are two extras
(above and below) for a total of 6 per cylinder.
No gasket was used most of the time, but did
try copper which worked well when I dropped
the comp ratio.
Stanley 路
Dave, do you still have the old godfrey's blower ?
Doug Sweetman 路
Bloody good effort Dave, well done 馃檪
Must be satisfying.
Bug_racer 路
Just wondering what carb venturi size are you running ?
shiftyvw 路
I thought the motor was alcohol injected? Hilborn style system?
dangerous 路
The car is using mechanical injection with four 56mm butterflys.
dangerous 路
Well today in Sydney is another event where the Honda
may take both ends of the record, so here is a look at the certificate before it is old history.
[ Edited on 3-1-2006 by dangerous ]
dangerous 路
Here is some wheels I just got.
On the drive home I think I will slice them up and make them 4" on the front, and widen to 7 or 8" on the rear.
They are 15 x 6" now.
